Here is a link to the driver download page. Under DRIVERS AND SOFTWARE, choose "photocopiers", then scroll down to the model number and select. Then pick either Windows 7 or Windows 7 64-bit as desired. If it won't open a window, right click on the option and choose "open in new tab".
http://support.sharp.net.au/drivers
SOURCE: sharp AR-M236 Fault U2-40
Hello sir; This error code require reset the procedure as follow;
press "#/p" " . " "clear" " . " then enter 16 press start enter 0 press start again, press "clear all" machine will back to normal.
SOURCE: I need to obtain a meter reading for sharp ar-m236. How do I do that?
Simply press and hold the copy mode then you get the meter reading and toner percentage status
SOURCE: Sharp AR - M161 Copier Driver for Vista
There is a vista driver available for that model as long as you are talking about the M161 not 161. Do you have the optional print kit installed or only parallel interface. If you only have the parallel connection it requires the GDI driver which can be downloaded from Sharpusa.com under support then type your model and select OS and driver type GDI
Hope this helps,
TankMurdock
SOURCE: sharp ar-m236 error code H4-21
-H4-21 means: Sub heater lamp abnormally low temperature detection. The setup temperature (about –25°C: Sim 43-1-1) is not reached within the specified time (about 32sec) from turning on the power ON SW. (When the temperature falls below 140°C in the standby mode.)
-Causes:
Sub heater thermistor defect
Sub heater lamp failure
Sub thermostat failure
Control PWB failure
-Check the sub heater lamp blinking with SIM 5-2-2.
When the lamp blinks normally: Check the thermistor and the harness. Check the MCU PWB thermistor input circuit.
When the lamp does not light: Check for disconnection of the heater lamp and thermostat. Check the interlock switch.Check the power PWB and the MCU PWB lamp control circuit.
Clear the display of self-diagnostics with SIM 14.
The H4 errors will not reset by themselves. You must enter service mode to reset this error even if the problem has been repaired. The reset process is outlined below (DO NOT USE ANY OTHER FUNCTIONS IN SERVICE MODE):
Press the following sequence: "#/P" "*" "C" "*"
Type in 1 4
Press start
hit 1 for yes
hit start
Unit should power off and the restart.
This will
help. Thanks please keep
updated.please do rate the solution positively .thank you for using fixya
SOURCE: Sharp AR-M208N copier with error code U2-40. What
reset u2
press c -interrupt-#-interrupt
press 16
press start
machine off
again machine on
remove this signal.
