Whirlpool GEW9250 Electric Dryer Logo
Brooke Egan Posted on Nov 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool duet dryer wont start
I have an electric whirlpool duet dryer that wont turn on when the power button is pushed. but i noticed the heavy duty light on the dial stays on unless I unplug the machine. we have already replaced the control board and had a technician out that could not fix it. sometimes it works and that is when the light on the dial will move but mostly it stays stuck on heavy duty and its lit up.
Anonymous
Level 2:
Champion:
  • Expert 249 Answers
  • Posted on Nov 30, 2008
Anonymous
Expert
Level 2:
Champion:
Answers
249
Questions
Helped
167942
Points
364
Sounds like the door switch
My Whirlpool Duet electric dryer WED9400SW0 dryer turns on but when I push and hold the start button it won't start rotating. It worked fine all weekend and then today, nothing. Help??
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
1helpful
Dryer will not start when pushing start button it just clicks once
This sounds like a problem with the thermal fuse blown which is wired in series with the motor. Power to the motor is terminated when the thermal fuse blows and the motor cannot run. No dryer function works when the motor cannot run. Click on the link below for the detailed instructions in troubleshooting this kind of Whirlpool Duet or Kenmore Elite dryer problem.
Troubleshooting Whirlpool Duet and Kenmore Elite Electric Dryers Not Starting
Whirlpool duet does not turn on when the power button is pushed no lights come and no sound the interior light works and then theres the odd time you push the power button and it works fine
sounds like the door switch/latch is going bad. You can test it here is a website that will help:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
1helpful
Start button will not initiate on cycle. Get 3 beeps.
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Dryer wont turn on just has a click sound when start button is pushed
A dryer may not start for many reasons...
heatman101
2answers
Dryer wont start - no lights
Dryer door does not think it is closed. There is a sensor on the top of the door that is probably not making contact with the door. Trying pushing the top part of the door and holding it then press the start button.. if the unit starts running then you know what it is. I just had one of these dryers delivered today and had to find out about this by myself tonight!!
Whirlpool dryer has power, but drum won't spin
More likely does have a belt. Get me the model number and I will see if I can help you on this problem, Thanks, Sea Breeze
2answers
My dryer wont start
check and see if you have 220 volts to your dryer using a volt / ohm meter find the cord and remove cover take meter and go across (1 test lead on left and one on right) side of cord there should be 220 volts.check this and get back to me. if no 220v trip breaker back and forth and try again
Top Whirlpool Dryers Experts
Virgil Watts
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Eager
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
