SOURCE: Rotary lift will NOT lower...has a code of 10 beeps...it will raise up.
Can you refresh your question? What is your question exactly?
Performance Chip Tuning
Removal
1. Disconnect the battery ground cable.
2. Drain the cooling system. For additional information.
3. Remove the accessory drive belt.
4. Raise and support the vehicle.
5. Disconnect lower radiator hose from the water pump lower tube.
6. Remove the engine mount nuts.
Lower the vehicle.
7. Remove the cowl extension panel. (Thats theone with the wiper arms go through).
8. Disconnect the water bypass hose and the heater hose from the water pump outlet tube.
9. Remove the water pump outlet tube bolt and position the tube assembly out of the way.
10. Install the lifting eye to the exhaust manifold.
11. Attach engine lifting equipment and raise the engine 127 mm (5 inches).
12. Remove the bolt and the accessory belt idler pulley.
13. Remove the bolts and the generator support bracket.
14. Remove the four bolts and the water pump pulley.
15. Remove the water pump. Remove the five nuts. Remove the five studs.
Remove the four bolts. Remove the water pump, lower tube and gasket as an assembly.
