HP PL4260N 42 in. Plasma HDTV Logo
Posted on Jun 05, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My HP PL4260N 42 In. HDTV Plasma Television tv doesnt show anything but i can still hear
It doesnt show anything but i can hear
Anonymous
Level 3:
  • Master 1,238 Answers
  • Posted on Jun 06, 2012
Anonymous
Master
Level 3:
Answers
1238
Questions
0
Helped
329702
Points
3603
If your TV is plasma the only part you need to replace or check is y sustain board..You should replace it to work fine again
3 Related Answers
Anonymous
  • 760 Answers
  • Posted on May 20, 2011
SOURCE: HP PL4260N 42 in. HDTV Plasma Television. The
You need to replace your lower Y drive board. Looking at the back of the set it is the board on the far left, bottom of the two. Should be about $50.00.
Anonymous
  • 8 Answers
  • Posted on Mar 20, 2009
SOURCE: Black screen on HP PL4260N 42? Plasma HDTV
The problem is the "Y-SUS" board. It is inside the set on the left side with several aluminum heat sinks, under the left side brace bar. You can order this board from Union Electronics at www.ued.com .Search for part number: TNPA3243AB-PA
It lists for about 115$
Anonymous
  • 6 Answers
  • Posted on Sep 06, 2010
The problem is with the YSUS board. Also 1 or two fuses (4A) will be blown so you will need to replace those along with the YPPD-J018C Hybrid IC module that is under the large heat-sink. I'm an EE in my day job so I have done this sort of repair from time to time but it can be intimidating unless you have very good soldering skills and a good solder station such as a MetCal. You will need a lot of heat to free the pins before prying this IC up. Failure to do it correctly may lift some of the delicate traces and the new part will not work! When removing the IC I always add leaded solder on these lead-free boards because it flows better. Also adding extra flux and using a Soldapullit Solder Tool works well. You keep adding the solder and sucking it back up...until the pins are relatively clean. Removing the IC still took me about 1/2 hr. to get enough solder sucked up until I finally was able to stick a screwdriver under it and pry it up. Do this gently, on several places on the IC to break it loose. On my board Q1 was blown but since there 4 of these same little semi-conductors, your problem might be Q2, Q3, or Q4? They are easy to spot because they blow apart catastrophically, there was black soot around mine. Also, one of the main reason this part failed is because the white heat sink grease was dry. This means that the heat-sink was not able to adsorb the heat from the board as well anymore and then it just got too hot and failed. So use a good high end thermal grease when you put the new YPPD-J018C part back on the heatsink. Something with silver like Artic Silver will cost about $10.00 a tube. This will make the TV last much longer. The YPPD-J018C part should run you anywhere from $39.95-$49.95 plus shipping. Both Suburban Electronics in MD. and Rich-Tech have the part. Good luck!
Picture just went out on my tv but I still have sound
I have the same problem with my HP PL4260N 42" Plasma HDTV serial # CNH6141988, model # CPTOH-0602. I have perfect sound and can change channels still with sound but NO PICTURE. I am a consumer with a question that need the advise of an expert.
2answers
I have a HP PL4260N TV. When I turned it on, it
Before doing anything to your TV, try to reorient your
antenna. Then, if nothing happen, you may now call
service to adjust or replace component part.
White lines at the top of my hp 42 inch plasma tv.
This HP model is know for many defects. It was sold by HP with a board problem. Contact us to get your TV fixed as a group. [email protected]
No Image on PL4260N HP Plasma Tv
HOLA HUMBERTO, SI ESTAS EN MARYLAND YO TE PUEDO REPARAR ESE TV POR MUCHO MENOS DE ESO. BUENA SUERTE [email protected]
Tv screen is black and flashes white
HP sold this TV with a bad board and they knew it was bad but still sold the TV's anyway. Our group is taking action to protect consumer from this type of corpoarte greed. Contact us: [email protected]
Hp 4260 plasma tv
It's a common problem, but not the only one, it could also the the z-board
Top HP Televison & Video Experts
 Mikey
Mikey
Stan Ford
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
