SOURCE: how to set time on cartier chronoflex?
to set the time and date of cartier watch , full the crown at half setting possition then wind it until the date move push the crown to the normal possition then full the crown twoo times to time setting possition then wind it again until you search the correct time,fush the crown to the normal possition after setting,
SOURCE: how to change the date on cartier santos chronograph watch
There are two positions for the setting crown all the way out is to set time,one click out to set date.To set the date you must first set the time by moving the hands around clockwise until you see the date change(midnight) then continue around to the correct time.Then push crown in on click and set the date
SOURCE: broken glass of my cartier watch
search for horoligsts on the web some of them can cut new glasses. if this helps please rate joe
SOURCE: Setting time and date on my Cartier Pasha watch.
Do not be so afraid. Unscrew that big crown fully, pull off and then you will see the real setting crown(quite small one), called an underlayed crown.
That little chain is hard enough to withstand your pulls, unless you are drunk. :)))
When you get that small crown handy- you can set the time and all the features.
If the small crown is not moving, your watch is rusty and you will need a proper watchmakers help.
Don't forget to rate, please.
SOURCE: set date on Cartier Tank Francaise Chronoflex
