Hi all, I'm printing from my Brother MFC-6490CW and the print job freezes at the fourth page. I tried deleting the print job through My Computer and through the server it is connected to, and I ran a delete print jobs command. This deleted the print job successfully, and I restarted my computer. The print job restarted unprompted when the machine booted, and froze again on the fourth page. Any ideas as to what may be happening? Thanks, -Mike
SOURCE: Brother mcf7220 will not print..says "cancel printing" "job cancel"
firest you swithc off all the printers and wait for some minute then clear all printers queue by going in to printer folder then restart your system.
SOURCE: "Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
SOURCE: I can not print
You could try to use static ip to remove possible problems with dns retrieving:
Also, if it works, you can change the network settings for scanner driver to go to ip address too instead of dns, even if it isn't a problem right now, it could later be.
SOURCE: Printer says "Unable to print 70"
Usually that error means the encoder strip behind the carriage assembly is out of position or very dirty. Best to remove the top cover to correct, you might also find a scrap of paper either on the extreme right or left stopping the carriage from moving properly.
SOURCE: I have a Brother MFC 6490cw and can't Get The
if you have done a couple cleanings and it has not helped, its one of 2 things, either your ink cartridge is empty and needs to be replaced, or the nozzles are clogged on the printhead, also air can be in the turbing causing it not to let the liquid flow.
thanks adi
