My active speaker won't power up. There is no lights, sound, noise. I have checked the power cord and on/off switch and the fuse inside with a multimeter. Everything of this is ok. The speaker have only been used on low volume for coctailmusic, and have never been overheating. Anybody have a proposals for this problem...?
SOURCE: Signal light stays on, no sound output
T14 is part of the +15v power supply that feeds the input board.
It is actually a transistor.
If this is the only problem on the board, then this transistor could be resoldered back on but you will have to make sure it tests OK and it attaches to the heatsink the same way it came off. ie make sure it is electrically isolated from the heatsink
It seems if there is no fuses blown on the power amp board you might be one of the lucky ones.
In my opinion this amp is a clever design but is under-engineered for robustness
SOURCE: Volume reduction with same input ( 4 years old),
What are you using to feed the sub? Are you sure that the signal level you are presenting to the sub is the same?
Dan
