Restriction code means Unlock code .It's helps to remove the network lock in the phone.You can get the RESTRICTION CODE from the site wickedunlock.com/unlock-your-phone/rs11wp2/ and UNLOCK nokia 3200 so that use with any GSM network sim card.
SOURCE: Restriction code for Nokia 6288
i have the same problem, call up three and tell them you wana unlock the phone and theyll give you the code for free now except i cant get the code because the phone wasn't originally mine and it's under some one elses name so they wont give me the code but good luck! =]
SOURCE: nokia 6500 slide
YOU CAN GET A BB5 TURBO SIM, ITS A PIECE OF PLASTIC WHICH HELPS BY-PASS THE SIM LOCK PROTECTION COMPLETELY CHECK OUT THIS LINK MATE :
http://cgi.ebay.co.uk/BB5-TURBO-SIM-CARD-UNLOCK-NOKIA-E65-N73-N95-6300-6500_W0QQitemZ110292003241QQcmdZViewItem?hash=item110292003241&_trkparms=72%3A12|39%3A1|66%3A2|65%3A12|240%3A1318&_trksid=p3286.c0.m14
SOURCE: nokia 5310 security code unlock
Check this
On the main screen type in:
*#06# for checking the IMEI (International Mobile Equipment Identity).
*#7780# reset to factory settings.
*#67705646# This will clear the LCD display(operator logo).
*#0000# To view software version.
*#2820# Bluetooth device address.
*#746025625# Sim clock allowed status.
#pw+1234567890+1# Shows if sim have restrictions.
*#92702689# - takes you to a secret menu where you may find some of the information below:
1. Displays Serial Number.
2. Displays the Month and Year of Manufacture
3. Displays (if there) the date where the phone was purchased (MMYY)
4. Displays the date of the last repair - if found (0000)
5. Shows life timer of phone (time passes since last start)
*#3370# - Enhanced Full Rate Codec (EFR) activation. Increase signal
strength, better signal reception. It also help if u want to use GPRS
and the service is not responding or too slow. Phone battery will drain
faster though.
*#3370* - (EFR) deactivation. Phone will automatically restart.
Increase battery life by 30% because phone receives less signal from
network.
*#4720# - Half Rate Codec activation.
*#4720* - Half Rate Codec deactivation. The phone will automatically restart
If you forgot wallet code for Nokia S60 phone, use this code reset: *#7370925538#
Note, your data in the wallet will be erased. Phone will ask you the lock code. Default lock code is: 12345
Press *#3925538# to delete the contents and code of wallet.
Unlock service provider: Insert sim, turn phone on and press vol
up(arrow keys) for 3 seconds, should say pin code. Press C,then press *
message should flash, press * again and 04*pin*pin*pin# \
*#7328748263373738# resets security code.
Default security code is 12345
Change closed caller group (settings >security settings>user
groups) to 00000 and ure phone will sound the message tone when you are
near a radar speed trap. Setting it to 500 will cause your phone 2 set
off security alarms at shop exits, gr8 for practical jokes! (works with
some of the Nokia phones.) Press and hold "0" on the main screen to
open wap browser.
Thanks.
SOURCE: Need unlock code for nokia 2700 (it
Hello Konstantells,
Before going to the procedures i would like to warn you that DO NOT ENTER WRONG / GUESSED CODES TO UNLOCK THE PHONE. If you do so your mobile might be in total hardware lock and the phone will be of no use.
Procedures: -
- Remove the sim card from your mobile
- Switch On the mobile
- Ignore the warning message
- Type #pw+CODE+1# (in some country 7# instead of 1# is used)
- A message will pop up showing 'Sim Restriction Off' Or 'Sim Restriction Removed"
- Your mobile is now unlocked
please visit fixya.com if you have any further doubts
Good Luck!
please rate and leave a comment. thank you!
