SOURCE: replace hard drive on sony laptop vgn-sz330p
Most hard drives are easy to get at, not on this model tho. If you follow this link. At the top of the screen click on next for each of the stages or use the drop down menu. Site was a bit sluggish when I went on to check so be patient with it.
http://laptoplogic.com/resources/detail.php?id=43&part=resource&page=1
Good luck
I'd appreciate you rating me if you find this helpful
SOURCE: sony vaio vgn cr200e drive
Western Digital Scorpio WD5000BEVT Mobile Hard Drive - 500GB, 2.5", looks nice. I haven't seen any larger yet.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4322423&CatId=1277
SOURCE: Need service manual or instructions on replacing
The hard drive is inside of the laptop and not accessible from the outside. The way to get to the hard drive is to take out all the screws from the bottom of the laptop, take the keyboard out and there may be some screws there that need to be removed. The dvd drive needs to come out and where the dvd drive normally is, check for screws there.
At this point you can remove the top cover assembly and you will see the hard drive. Remove the screws that are holding the hard drive in place and then it will come out.
Testimonial: "Thanks I realize that the unit needed to be seperated however without a service manual there may be some important tips that could be missed."
SOURCE: How to change hard drive on Sony VGN-N130G?
I need the model number printed on the front of your case, VGN-N130G does not exsist on the sony web support page. http://support.vaio.sony.eu/computing/vaio/index.aspx?l=en_GB
Usually there is a cover under your laptop that is marked.
Remove 1 or 2 screws and your harddrive should just slide out.
