On family map when trying to locat family sometimes a small blue circle or larger pink circle will around that member. What does it mean
SOURCE: Pink horizontal stripes on my monitor
If youve tried pressing the degaus button on the monitor and the same result then either your graphics driver is corrupt and needs to be updated from the manufacturer web site or the monitor is on it's way out. Try a friends monitor on your system or your monitor on a friends, if it's the same on a friends ststem, it's a belated Xmas present for yourself.
SOURCE: lg ru45nz60 rear projection television goes pink and blue
Change convergence board or convergence ICs, test them.
SOURCE: My Screen is pink
there must be some problem with the hardware of screen. get it checked from a professional
SOURCE: Printing blue on top of pink
There is a common colour problem with this model printer it is caused by the scanner assembly (there's a fan that blows megenta into the scanner unit).
Solution is to clean the scanner mirrors.
SOURCE: blues are pink?
either ur blue cartridge is empty or maybe the nozzle of ur blue are clogged .normally the dark blue colour is made up by mixing of blue and pink . because ur nozzles of blue are clogged or maybe the blue is empty it prints only in pink when u command for blues.replace the blue if its empty or clean the nozzles if its clogged.
