Have already downloaded the MTP toolkit.
SOURCE: Stuck in Upgrader etc
well i own one too and thats probly the hard drive being stuck...just smack it against something hard , like sorta bump the rubber armor against the heel of your hand or a countertop...worked good for me...ya have to do it a few times...dont worry rio is defunct so theres really no warranty to think of anywayz
SOURCE: rio s10
? Verify that the USB cable is securely inserted into the USB port on both the Rio Carbon and your computer. ? Connect the USB cable to a USB port on the back of your computer rather than to a USB port on the front of your computer. ? If using a USB hub, connect to a powered USB hub. Unpowered USB hubs may not work. ? Remove USB extension cables from the connection path. ? Disconnect other USB devices. ? Both Windows XP Service Pack 1 (SP1) (or greater) and Windows Media Player 10 (WMP10) must be installed for your computer to detect a Rio Carbon set in MTP mode. ? If you do not want to install SP1 (or greater) and WMP10 on your computer you should disconnect the Rio Carbon and change the Transfer Mode setting to MSC mode. Good Luck
SOURCE: Need down load for Rio Sport S30s MP3
Check out this website for the software that came with the Rio Sport device (clcik on the software tab - depending on your Windows version, you may need to also select the drivers tab aftwerward):
http://www.digitalnetworksna.com/support/rio/product.asp?prodID=212
-Tha Mp3 Doctor
SOURCE: Rio Nitrus MP3 Player
Ok Rio nitrus is great litle thing, and I had the same problem. This is what you should do:
1) download latest firmware for rio nitrus http://www.rioaudio.com/support/rio/downloads/Nitrus/RioNitrus_firmware_123.exe
2) unpack firmware
3) connect Rio Nitrus to your comp;
4)While holding menu buton press power button, you sholud see on display showing UPGRADER text;
5) Then upgrade the firmware ( note that this will erase all the songs- read the read me file that come with firmware);
Although I allready have the same version of firmware v.123 like the one that upgreded this solved the problemm.
SOURCE: error message "failed to connect to player" "data blocked failed"
Don't buy an iPod...
I would recommend wiping and rebooting your player cos it's cheaper:
Windows only.... Please post if you are not using windows...
Open My Computer with your Rio plugged in.
Right click on your Rio player and click on format.
Leave the default values - if it asks you something then use your initiative.
Then click on format.
Then
when it has finished formatting go to your firmware (can be downloaded
from: http://www.digitalnetworksna.com/support/rio/product.asp?prodID=112).
Follow the instructions and then it should load the firmware onto your player.
When it has done then your player should (in theory!) work properly.
Hope this helps
Mowcius
