Computers & Internet Logo
Anonymous Posted on Jun 04, 2012
Hi. I've just purchased a computer but without the harddrive. I do have the o/s key but I'm not sure how to install the system without disks. Any help would be greatly appreciated!
Anonymous
Level 2:
Scholar:
  • Expert 106 Answers
  • Posted on Jun 04, 2012
Anonymous
Expert
Level 2:
Scholar:
Answers
106
Questions
0
Helped
34772
Points
295
You have to borrow or buy the install disks (Not the recovery disks), the problem is that not all keys work with all copies of the system.
  • 1 more comment
  • Anonymous Jun 04, 2012
    I have install disks for some of my other computers but don't know that they will work. Haven't yet received the computer I've purchased. Not quite sure if the system is Vista or Windows 7. Do you think if they are both HP it might work? And what might the danger be of installing a disk that is not compatible?
  • Anonymous Jun 05, 2012
    The key has to be for the software you're going to install! You can't use a Vista key for Windows 7 as far as I know.
  • Anonymous Jun 06, 2012
    Sorry, I wasn't entirely clear. I have install disks for Vista and Windows 7. I was aware that the keys weren't interchangable. I mean't more the difference between 32 and 64 bit. I have now received the computer and it is Vista, unfortunately. So, of course, I now have to get another key to install Windows 7. Thanks for your help.
5 Related Answers
Anonymous
  • 13 Answers
  • Posted on Mar 21, 2009
SOURCE: trying to copy harddrive to another harddrive.
To clone a disc , acronis true image home is a very good software . A free software based on it is available from seagate called as disc wizard but it will only work with seagate drives. about hard drive not being detected , try upgrading your bios . Some bios dont detect new higher capacity harddrives. Do tell what is your drive capacity.
labcourier14
  • 21 Answers
  • Posted on Aug 09, 2011
SOURCE: I've been trying to get
Go to Microsoft.com./downloads. You want the ESSENTIAL CODEC PACK. Follow the instructions.
sonicboomele
sonic boom electronics
  • 1557 Answers
  • Posted on Jul 01, 2011
SOURCE: I've replaced my corrupt harddrive,
you need to contact the company you bought the computer from and ask them for the phone number to the software packege company they use with there computers if you contact them they will send you a copy of the vista install
Anonymous
  • 1672 Answers
  • Posted on Sep 15, 2011
SOURCE: I would like to reboot
You forgot to tell us the Motherboard type.
Click either F2 or Delete( depends on the type of board ), after you started the comp and shows the memory and HD capacity on the monitor.
Bios setting will then pop up, then go to maximum default settings....save and exit.... it will restart by itself.
Hope that helps!
jeffsterrett
Jeff Sterrett
  • 108 Answers
  • Posted on Oct 25, 2011
SOURCE: had to replace hard drive. Can't reboot using
You may have just recieved the wrong set of restore discs for your computer. Have you replaced the motherboard in this computer at any point? The discs look for a specific code stored within the motherboard bios to keeps people from using system restore discs to install an operating system on whatever computer they want.
You can try contacting the manufacturer to see if they will send you another set of restore discs. They often charge for these, however, if you explain your situation to them they may send you another set at little to no charge.
Hope this was helpful
First boot of Win 7. New PC build
Hi.
First of all when you are in the BIOS and have set the DVD/CD drive as the first boot device make sure you save the settings before you restart the computer as it will not remember the changes if you don't.
Make sure that the lens on the CD/DVD drive is clean and also make sure the Windows 7 install disk is clean and free of any finger prints.
make sure that you keep tapping a key when the drive spins up as sometimes people miss the "Press any key to boot from CD/DVD" message.
If you still can't get the disk to boot then try the install disk in a working PC and see if that reads the disk. If it does then the optical drive could be faulty or does not support DVD format.
Regards.
I'm installing a biostar a78ldm2s and everything turns on but I keep getting a read disk error on the hard drives that I try to use. I've tried 5 different hard drives and get the same result.
Hello here you can download a manual:
http://www.biostar-usa.com/app/en-us/support/download.php
By entering the right mainboard number.
Try to set the bios to factory settings.Load default settings.
And set the boot order: first boot device:dvd, second, the harddrive.
If you are using a IDE drive make sure its set as master.
A sata drive does not have that function.
Make sure the windows disk is clean and without scratces.
Here is a youtube video that shows you how:
http://www.youtube.com/watch?v=sMc5ukMguEo
Good luck
Disk Crash!
Borrow an operating system disk from a neighbor, friend, relative or co-worker to reinstall windows. Just borrow the version that your Certificate of Authentication (COA) sticker on the bottom of the laptop says. Also make sure you can read the Product Key Code on the COA. Also get the product key code for the disk you borrow because sometimes during installation or activation it will ask for the Key that is on your sticker, and sometimes it wants the key from the installation disk.
Just make sure you borrow the same version of windows that your COA says is installed on your system otherwise you'll have problems activating it.
2answers
I just got a pc from a friend without HDD, i put my own HDD in but when i start up pc constantly beeps until i shut down.. so irritated.. plz help, thanks
The beep codes indicate there is a problem keeping it from starting. You code post the model, etc. of the computer, and the number of beeps, and if there are long or short beeps. Mostly these are memory and/or video. If you can, disconnect the hard drive, cd, and any extra cards (sound card, modem, network). Re-seat (remove and re-install) RAM and video card, then try it again. Re-post if you are still getting beep codes with # of beeps, etc.
Hi. my disk is dismounting every few minutes while i'm working with ADOBE CS3 applications on a WINDOWS7 system with an Intel motherboard model DH67CL. it happens mostly when i use the eSATA...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
I've replaced my corrupt harddrive, that was preinstralled with Vista, with another harddrive. I have product key on bottom of computer for OS. How can I reload system on new harddrive?
I've had my WDBAAF0015HBK My Book for a few months, but now I have a new computer and went to attach it but it doesn't register. I can't hear anything whirring around inside it, but the front...
2answers
Hi I've Vaio VPCSC1AFM with Win 7, boot is impossible -"Operating System Not Found", HDD is also not visible in BIOS. I can hear that HDD is working.
* Look in your BIOS, I've it can detect the HDD.
( Press the F1 or F10 key after restarting the computer) * Make sure all the cables are connectedproperly.
* It might be a jumper setting.
I've you have 2 HDD's on 1 cable, you need to have 1 Master & 1 Slave,or else your HDD(s) wont show up & other problems.
Jumper settings below (Yourjumper settings might be different !)
I've this all didnt work, either your HDD or your MOBO is broken.
Computer- reformat
In order for the computer to work, and for you to reformat the harddrive, you will need a bootable disk, either one which has a drive utility on it in order to reformat and partition the harddrive or an operating installation disk which includes a drive utility (any windows installation disk has it) - without one you will neither be able to properly reformat the harddrive nor install an operating system on it in order to use the computer.
As you have stated, this is obvious, and your problem is that you do not have an installation disk. A restore disk would not help if you reformatted the harddrive.
You can either purchase a Windows operating system disk, find one (no, not anything illegal - I have spare copies of windows and all of my geek friends have spare copies, because frankly of issues like this),
or download a copy of Linux and burn it to a cd - Ubuntu is a decent choice for a starting Linux user, and is very easy to use (works alot like windows, has tutorials, etc) and is completely free - you can do a search for Ubuntu Linux on google and you will be able to download a copy which can be burnt to disk or request a disk be sent to you, though I cannot remember if they still send free Ubuntu disks out.
Linux typically runs very well on limited resource computers such as the one you are in possession of. Did I mention it was free? If nothing else, you can use it to reformat the harddrive using their Live Boot disk - it allows you to use the Ubuntu operating system without installing it. You boot from the cd and can use their harddrive utility, or install Linux to the harddrive, or just check it out to see how it works.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
