Quite often now two red intermittently flashing lights showing there is a problem when the wash doesnt want to go through the spin cycle
The most common problem that I have come across is that the pump outlet is blocked or the pump is jammed.
You should have instructions on pump clearing but if not, there should be a hatch in the front of the machine at floor level. Open this and there should be a small hose with a tap that allows you to empty the water. When all the water has gone (be patient - it is a small pipe) unscrew the stopper and shine a torch down the pipe.
If there is any obstruction, remove it with something long enough to reach the pump blade and check that the pump rotates.
Re-assmble plug and replace cover.
SOURCE: aeg 76669 oko lavamat machine not
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
SOURCE: BOSCH WASHING MACHINE WONT SPIN, FLASHING RED SPIN LIGHT
check the pump clean out. sounds like something is jammed in the pump
SOURCE: could you tell me why my candy go 482 washing
could you tell me why my candy go 482 washing machine doesnt always spin and the stain vanish and 90 minute lights flash together
SOURCE: bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
SOURCE: re Baumatic BK6EL, the washer stops at the
Hi Same problem but easy to fix.
Remove back cover of machine. Look to the lower end of the bowl and you will notice a stainless steel wire with hook attached. If this is hanging loose that will be your problem. Reattach the hook to the grey coloured lever , it has a hole drilled through it at the extremity. The wire pulls on this lever to disengage the drum brake during the spin cycle.
