Antenna broke off, need to replace
Did the antenna break off in the mount or did the mount break.If antenna broke off in mount I would try drilling and tapping it.If you need a whole mount.Remove plug from back of radio attach good mechanics wire to it undo outer mount when you pull the wire out of the car the mechanics wire will follow afer you get it out put the mechanics wire on the new one tape over the wire to make it a smooth transition and pull mechanics wire inside the vehicle to reroute the antenna wire back to the radio.Be carefull you shouldnt have to pull super hard
SOURCE: 2002 Chrysler Town & Country Evaporator leak
THERE ARE SEVERAL EVAP HOSE LEAK SPOTS ON THESE VEHICLES..UNDER VEHICLE BY EVAP CANISTER,UNDER AIR CLEANER..ALSO LDP VENT VALVE NOT HOLDING VACUUM WILL SET A LEAK CODE..SMALL BLACK VALVE WITH A HOSE ON EACH END WITH A SMALL VACUUM HOSE ON TOP..IT SHOULD HOLD VACUUM WITH HAND HELD VACUUM PUMP..HAVE ALSO SEEN SPLIT HOSES NEAR EVAP SERVICE PORT LOCATED NEXT TO AIR CLEANER HOUSING
SOURCE: 2002 Chrysler Town and Country
Ok, i'm assuming your replacing them, there is an oval rubber stopper on the backside of the rotor, in the backing plate, located near the bottom. it will tighten or loosen the e-brake shoes inside the rotor, loosen them all the way off, then get a big hammer and give them a really good smack, be carefull not to damage the wheel studs, if your reusing them hit on the hat of the rotor, if replacing you can hit right on the rotor face.
Use some antiseize on the hub before installin your new rotors, and don't forget to readjust your
e-brake and reinstall the rubber plug
SOURCE: Chrysler trouble code U110C on 2005 chrysler town
encrypted software ,dealer only----yes i know you are showing a reading but it doesnt mean anything or if it does it shows a different code .so your snap on or mac tools scanner is a waste of time and money.Nearly all new motors from 2005 are using encrypted software to stop general mechanics like me from working
SOURCE: 2001 Chrysler town and Country tire size
the sticker on the drivers door or door jamb will have that info. plus it is on the side of the tire, starting with P___-__-__
SOURCE: how to remove starter for 2002 chrysler town &
There are two bolts to remove, opposite sides. One is a normal bolt, the other one is hidden by wires. Remove the nut on the ground wire, remove the ground wire, use deep socket over this to remove the bolt. It's easier than you think, about an hour and a half total.
