Here is a direct link to a user's manual for that model:
http://www.appliancefactoryparts.com/content/pdfs/114658.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at
WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
You can just run the unit at the stock settings initially and then after a day or two of operating, you can adjust the desired humidity level up or down if required. If you find that your coils are freezing up with ice, then the unit is running a little too much for the ambient conditions. You can always try adding a little heat to the room if necessary since a dehumidifier will not work well if the room is too cold.
Please comment back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
