When my game witch saga opens on windows 7 it loads but will not let me play my one level to another, then abobe pops up, can you please help me.
SOURCE: New Windows 7 can't load deadlock 1996 disk.
I managed to get Deadlock running onWwindows 7 by using XP Mode - you can download it from Microsoft here: http://www.microsoft.com/windows/virtual-pc/download.aspx
SOURCE: Titanic adventure out of time. Got windows 7 home
you can't do much on a 64-bit computer so i would recommend getting a 32-bit version but i don't think that game would work regardless on win7. it's a really old game so i wouldn't imagine that it would work on an operating system any later than winvista but winxp would be a safe bet.
SOURCE: Rome TW won't play on a laptop with Windows 7.
First thing is first, go to your install folder. (This is usually found in the C;\program files folder, i forget the full command path) and see if the .exe file is there. If it is not, try uninstalling and reinstalling the game.
hello..
have you tried this steps???
So this is my tut how to cheat on Ninja saga (Facebook and Orkut) and get more exp and lvl up fast:
So first you need these 2 programs:
1.Cheat Engine (http://www.cheatengine.org/)
2.Mozilla Firefox
So Lets Get Started:
1. Go to your Facebook And open Ninja saga (BUT DONT LOG IN)
2. Now Open CE (Cheat Engine) and for Process put Firefox
3. Now put in Value: "3B0008C25B5E0689" (Hex, 8 bytes ASROM)
4. You Should Get 2 Addresses, right click on 2nd and "Disassemble This Memory Region"
5. You should get new window on that window press right click and "Toggle Break Point"
6. Go Back to Firefox and press play on Ninja Saga
7. Go Back to CE and 2 times press F9
8. On Right Side of that window you should get EAX "XXXXXXXXXXX", press on that and put new value e.g. 144 (that will put you on lvl 2, later i will explain why only lvl 2)
9. Now right click and press "Toggle Break Point"
10. And F9 again
11. And Viola! You're on lvl 2 LoL
So now i will explain why not lvl up immediately on lvl 19....... you Can lvl up your Self only lvl by lvl (so if you wanna be lvl 3 you need to do this hole process over again and in EAX "XXXXXXXXXXXX" put right value), cuz if you lvl up your self immediately on lvl 3 you char will be deleted, this take time but its worth :DDDDD
So these are Values For Each lvl:
1-11 (but you are on start lvl 1)
2-144
3-378
4-544
5-733
6-No Code you Must lvl up your self with out cheating
7-1000
8-1600
9-2600
10-No Code you Must lvl up your self with out cheating
11-3600
12-4600
13-5600
14-6600
15-7600
16-9000
17-No Code you Must lvl up your self with out cheating
18-No Code you Must lvl up your self with out cheating
19-11000
20-13000
I Did This only till lvl 20 cuz if you go on lvl 21+ you wont have any skills and gold so you cant do quests.........in one word you will be weak..........
http://games.bbgsite.com/content/ninjasaga/guide/ninja_saga_exp_hack.shtml
cheers
