Korg M50 61-Key Music Workstation Keyboard - M5061 Logo
Posted on Jun 04, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Update right and left pannel please turn off what problem
4days ago when i was playing after15minutes it was sudden hanging,no sound no buttons switch worked, but today when i turn on it shows only update right panel update left panel please turn off. so please tell me the solution
charlie rodriguez
Level 2:
Novelist:
  • Expert 152 Answers
  • Posted on May 01, 2015
charlie rodriguez
Expert
Level 2:
Novelist:
Answers
152
Questions
Helped
131024
Points
485
Hello, there may be issues with your loaded programs, first I would try a factory reset, press global mode click the arrow next to basic and choose pre loaded data and PCG, press okay allow for it to reset it self, wait a few minutes before restarting, this updates the left and right panels. Hope this helps, Have fun playing..
Myo W. Shwe Shwe
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 08, 2014
Myo W. Shwe Shwe
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1051
Points
Up date right and left and then turn the power off. What wrong or who to operate of korg m50-61
Yamaha psr4000 no sound when i play keys
To start with try a master reset, whilst the instrument is off press and hold the top (highest) sounding key whilst turning on.
When the screen displays Yamaha release the top key.
If this doesn't solve the issue then it could be a number of things as the keyboard does a self check on startup and will hang if a fault is found. Check each rubber switch is not stuck down or even missing this can cause this issue. Please report back either way.
Dan
Becketts Music Ltd
Yamaha psr-e333. Can switch on but cannot play even the grandpiano func. Its just "yamaha" written on the display..
Dan
Becketts Music Ltd
1helpful
2answers
Why is gm voice not playing?
Hello, You may want to reset your machine, all data and pre loaded programs, for this you must turn on your M50 press the global mode button, click on the top arrow next to (basic) select option 2, load pre-preloaded demo data, you then choose all (PCG and demo songs). press OK. Your Korg will re install all factory samples, data and settings. Once completed It will then instruct you to turn off your machine. give it a minute or so to self upgrade before turning it back on, once you turn it back on you should see updating panel notifications right and left, you should be able to use all of the sounds and combi's available for M50. that's a factory reset. I hope this helps, Have a great day.
2helpful
We hava a Casio CTK-601 Synthesizer Keyboard. It was accidently left plugged in with a 12 volt adaptor. It uses a 9 volt adaptor. We do not know if it was having the following problem before or after...
That is a good detailed description. The factory reset is a good idea.
It sounds like a corrupted firmware. 12 volt instead of 9 volt is not a big overload, depending on the design. The fact that the adapter was very hot points to a serious electronic fault perhaps occuring. If the amp rating of the 12 volt one is adequate, this is probably the case. The 12 volt adapter could also get very hot if it is under rated for the job, which gives no real information about the fault.
It is possible that the electrolytic capacitors in the power supply could have been stressed and the power supply is now inadequate. The service manual would be handy in this scenario. If the digital electronics is corrupt or damaged, the chance of an economic fix is much less.
Feb 27, 2011 • Casio Music
Korg pa-50 no sound from right speaker but has sound from left
Several things to check:
If the speakers are cut off when externaal cables are connected to line outs, possibly the jack sensing switch for the right channel thinks that a plug is in there... you might cycle one in and out to see if that might fix.
Another thing is they LIKELY have a PAN control setting and it might be set full left. The external MP3 would NOT be under PAN control, only the keyboard voices would be affected by it.
Feb 01, 2010 • Music
How do i make my mpk49 pads work with samples, in other words, when i press the pad once the loop will play or the sample will play all the way threw, but right now when i press the pad, it only plays how...
Have a look in your manual at the sections on Note Repeat and Time Division.NOTE REPEAT] – Holding this button while
striking a pad causes the pad to retrigger at a
rate based on the current Tempo and Time
Division settings. The Note Repeat feature can
be synced to an internal or external MIDI Clock
source. [NOTE REPEAT] can function as a
latching or momentary button
19. [TIME DIVISION] – This button is used to specify
the rate of the Note Repeat and Arpeggiator
features. When [TIME DIVISION] is activated,
you can press one of the 8 switches to specify a
time division. [TIME DIVISION] can function as a
momentary or toggle button.
Please note that while [TIME DIVISION] is active,
the 8 assignable buttons will not function as MIDI
CC or Program Change switches until [TIME
DIVISION] has been de-activated.
20. [ARP ON/OFF] – This button enables and The manuals and updates can be downloaded here:http://www.akaipro.com/mpk49 Please let me know if this helps.
Nov 30, 2009 • Akai Music
Yamaha clavinova cvp-83s
Hi, did you manage to sort your problem as the same thing has happened to my clavinova (same model). Thanks.
I have the 2442 fx behringer ''XENYX'' mixing console, and while trying to operate channels 13/14 and 15/16 (these are both stereo channels with mono capabilities, and do not have XLR inputs) I only get...
Check you assign buttons and bottom (three black square buttons) and play with them. It sounds as if you are not sending to that side. You should use mono cables into left and right. I set pan on left all the way left and right, all the way right. Hope this helps.
Jul 06, 2009 • Music
Top Korg Music Experts
john h
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you a Korg Music Expert? Answer questions, earn points and help others
