Question about Pride Jazzy Select 6 Indoor Power Wheelchair
My battery charger for my Jazzy 600 does not light up or get warm when I plug it in. The chair has not been used for months.
Red power light comes on but charging light does not.
  • Teena McElroy Jun 05, 2012
    I tried to charge the chair battery but it did nothing. The chair was only used for 5 months prior to it sitting for awhile.
  • Anonymous Aug 23, 2016
    If you can take the battery's to a local auto part's store and have them load test they do not charge for this test.Good luck
    New Friend:
I tried to charge my jazzy. The charge light (red) remained on for several hours. Finally I moved the wire slightly the charge light turned green than faded to red. What is my problem? Your solution would be greatly appreciated.
Posted on Apr 10, 2014
SOURCE:
dromtonpa
  • 40 Answers
SOURCE: My Jazzy won't move.
If your batteries are truly charge they should read around 24.5 VDC. And if the freewheel lever is engaged and you still have no movement your probably need to get into a service tech. Also check the circuit breaker on the chair.
Posted on Apr 03, 2009
dromtonpa
  • 40 Answers
SOURCE: Jazzy 1113 Power wheelchair. Batteries are fully
Yes, the main controller module can be very expensive to replace. I would take it to a reputable dealer if the battery replacement does not help.
Posted on Apr 05, 2009
SOURCE: lights on hand control flash off and on and chair will not operat
There is a series of diagnostic flash codes associated with the controller. The diagnosis depends on which color and how many lights are flashing. If you post the combination, I can help you. Or you can download the Basic Operation Instructions of the Pilot Controller from the Pride website. The codes are listed on page two on the troubleshooting instructions.
Posted on Apr 14, 2009
  • 11 Answers
SOURCE: Jazzy 1103 will not charge. Power cord and
The battery charger is only made to last 1 year if you
re lucky. They are all made in China very cheaply and some only last a matter of months. If you are on Medicare they will replace the charger if necessary after a year. Good luck, hope this helps
Posted on May 16, 2010
HoverTech
  • 232 Answers
SOURCE: chair no longer charges, no flashing or blinking, lights,
The number of lights that are blinking indicate what the problem is. Visit this site to locate the type on controller on your power chair and you will be able to see that the blinking lights mean:
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Try to reset your manual brake release as this is a common problem.
If you continue to have a problem, contact your manufacturer or dealer for service. If your insurance purchased they power chair for you, they may also cover the cost of repairs.
Posted on Oct 20, 2010
Ideas Arlec PS906 mobility chair charger. It's saying that battery's charged, only on with one red light when charger off, all lights on when charger attached. It turns on but lowest of power, Elaine
Hi again I'm a bit confused a PsS906 arlec charger is a 12 volt charger ??? Can u supply more information .cheers Hi when u turn charger on red ( led ) should come on / when connected to battery / red & yellow ,( led ) should b on /it's in charging mode /when green ,,( led ) turns on battery is charged.cheers
Dec 09, 2017 | Health & Beauty
The operating instructions say that after 16 hours the red power/charge indicator light would go out, indicating the batteries are fully charged. After 3 days the red light on my unit is still on. The...
If it is new, send it back, but make sure you carefully read the instructions first. If is says the indicator light is red on charging and green when fully charged and it doesn't do that then the batteries or the charger are defective.
In future make and model are useful. And you posted to electric drills, but I recategorised it.
Jul 02, 2017 | Audio Players & Recorders
Vibration ane blinking red light
When a call on your phone comes in i will vibrate, flashes red when battery is low. The light will also be red when its charging. It will turn off when its charged.
Mar 09, 2014 | LG HBS-700 Bluetooth Headset
Jazzy charge light on chager does not come on
The red light indicates that power to the off-board charger is on. Try a different ac wall outlet that you know works. If a red or green light does not come on you will need to replace charger. Also check the condition of your batteries - dead batteries will not charge.
Mar 22, 2013 | Pride Jazzy 1103 Ultra Standard Power...
Plantronics ml10
Same problem for me: I start chargering (red light) and when I unplugged It don't power on anymore.
The solution for me was resetting the unit. Follow next steps:
-Start charging the ML10 (a red light will appear)
-Press PowerButton and Volume(-) (a blue/right light will appear for less than a second).
- Voila! It comes to life!
Feb 10, 2012 | Radio Communications
Bluetooth wont charge or power on. when charging the red light comes on. once disconnected from charger it wont come on
Indicator Lights:
1.Headset Status Headset Indicator Light
2.Powering on Steady blue, then intermittent flashes
(changes to standby mode)
3.Powering off Red appears and goes off
4.Standby Blue intermittent flashes
5.Charging battery Red solid light. Light indicator turns off when
battery is fully charged and headset is off.
6.Low battery Triple red flashes
7.Pairing mode Blue/red alternating flashes
8.Missed call Purple flashes. Press the call control button
to cancel flashing light.
9.Incoming call Triple blue flashes when ringing.
Power on and off:
1.Turn on the headset Press and hold the call control button until the
indicator glows blue. You will hear ascending
tones.
2.Turn off the headset Press and hold the call control button until the
indicator glows red. You will hear descending
tones. When power is off, indicator stays off.
If none of this is helpful then it may be that your battery is dead, if that is the case then you will need to replace the whole headset. The battery's are not replaceable.
Good luck from Headsets Direct!
Sep 21, 2011 | Plantronics Explorer 220 Bluetooth Headset...
The green light is on and the red light flashes 4 times and cuts off its not working
If your gps comes on and then flashes the red light four times and goes off back, then it means the battery is too low and it cannot power up. You need to charge it before using it. If you plug it in the car or to any power source, leave it for a moment, then check if the light will come on signifying that it is charging. Once it is fully charged, then it will be able to power on. If you plug it and it does not give any charging signal, then the power adapter might be bad and need to be replaced.Before replacing it, try out the adapter on another gps to see if it works. If it does not work, then you can replace the adater.
If there is no power in the gps is when the green light comes on and blinks yellow, then go off immediately.
Hope this information was helpful to you.
Dec 21, 2010 | GPS
When connecting up to charge red light comes on 'power on' button on front and no charging happens - any ideas? thanks
What does indicator light mean?
  • Steady red light: Battery is charging.
  • Steady green light: Battery is fully charged.
  • Flashing red light: Battery needs charging.
  • Flashing green light: The music receiver is switched on.
  • Flashing red/green light: The music receiver is available to be added to your phone.
Aug 24, 2009 | Sony Ericsson T303 Mobile Phone (Shadow...
Why does my phone not charge it has a red light on at the back
remove the batteries and put it again to reset the power.
Jun 15, 2009 | Sony Ericsson W890i Cellular Phone
Battery not charging
The charger may be bad. The red light shows that power is applied to it. So usally, unless the light itself is bad, no red light, no power.
Dec 27, 2007 | Vacuums
Pride Jazzy Select 6 Indoor Power Wheelchair Logo
1,138 people viewed this question
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
