Yamaha HTR-6130 Receiver Logo
Posted on Nov 28, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No audio comes from the rear right speaker. what am i doing wrong with connecting the speaker on the htr-6130?
Anonymous
Level 2:
Scholar:
  • Expert 107 Answers
  • Posted on Dec 03, 2008
Anonymous
Expert
Level 2:
Scholar:
Answers
107
Questions
0
Helped
50478
Points
260
Swap the rear right speaker to rear left make sure the speakers and speakers wire are OK
Initializer the unit as follow set the unit in STBY mode if you are not sure which mode turn off the unit with the remote control now the unit is in STBY mode. Pressing STRAIGHT and AUDIO SELECT keys simultaneously then press power STBY button on front panel the display will show 1: Analog ByPass use the PROGRAM knob to move up to 13 PRESET INHI then press 1 or 2 keys to change to PRESET RSRV then turn off power now unit reset to factory just turn on and try it
Let me know how do you go
Cheers
PS: this model have an update firmware if your is still under warranty bring it back to Yamaha or 1 of the service center Yamaha they are able to update for you. Due to confidence I can not post that firmware sorry for that inconvenience
1helpful
3answers
Yamaha HTR-6130 sound only from centre, rear or front speakers
its not how there connected its in your settings. rehook up all your speaker connections properly,then make sure you proram the reciever to recieve fiber optic,hdmi,digital coax etc in the reciver.
2answers
HTR-6130 will not turn on
Remove all speakers from the receiver and try powering it up again. If it still shuts down odds are it needs repair of one of the output channels.
1helpful
Front left and right speakers don't put out sound
Hit the button  "speakers/a/b/off" on the left hand side of the front panel until it shows that "speakers b"  are turned on.
No sound from the speakers when we use DVD or XBox
Take the remote and press theDVD button. That will change the sound system from TV to your DVD. When you switch back to TV, dont forget to switch this back by pressing DTV/CBL white button
Getting Audio to work with our Cable Tv
The HTR-6130 does not decode the audio from the HDMI inputs. It only acts as a switcher. You will need a separate audio connection from the cable box to the HTR-6130.
Right rear speaker has no audio
Swap the speaker wire from left rear to right rear if the speaker was from RR now work on LR side this prove the speaker OK then you problem in the receiver
If you swap the RR speaker to LR side and still not work then you
have that RR speaker open
Make sure you hook up speakers cable properly and not short from both terminal speakers and receiver the RED and Black poles
Let me know how you go
3helpful
4answers
PS3 connection to Yamaha HTR-6130 Av Receiver
URNOTME is right. HDMI is great and all, but wish i would have spent a few more dollars on a unit that supports switching. htr-6130 does pass-through, so you have to use seperate audio connections. really there is no use running HDMI into the receiver and then into the receiver and THEN to the tv. just go straight to the tv, then run your audio either optical (best) or coaxial.
22helpful
4answers
Yamaha HTR-6130 Front right and left speakers with no sound
As simple as this sounds, try hitting the speaker a/b button on the front of the unit, next to the headphone jack. I had the same problem, and was about to package the whole thing back up and go back to Best Buy when I hit this button and then the audio test worked.
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Paul Bade
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
