I removed power switch and it still wont stay in the on positon.
SOURCE: ???maximum user weight for Precor 9.45i
Normally most home treadmills are 250-300lb user capacity.
Call Precor with your model # and S/N and they can tell you exactly.
SOURCE: Trying to fix a 20+ yr.old treadmill (Precor USA
Dear Sir:
I hope you are very well, in union with your family.
Thank you by your request, and I will help you inmediately.
Please follow the next step with very carefully:
Makesure that the surge protector being used is properly grounded(Very Important) and turned on.Check that the treadmill power cord is properly plugged into the surgeprotector.
Checkto see that the key is inserted in the console.
Checkthe circuit breaker on the frame near the power cord. If the reset/off circuitbreaker has tripped, wait 5 minutes and then reset the breaker by pressing theswitch in.
4)Check the circuit braker panel house, and reset.
Static Shock Problems:
Many people face a conundrum when using a treadmill. The problem is that a treadmill has you walk or run in a motion that causes you to build up an electrical charge on your body while you are exercising.
The problem if you are swinging your arms, you are totally isolated from any common ground so the charge just builds and builds and many discharges have been measured above 30,000 volts.
You may say, how in a frost-covered hell can I build up 30,000 volts on my body without killing myself? Good question and it has a good
answer...there is very little amperage. It will pop you good when you do ground and sting but it won't hurt you.
The problem is that it can damage the treadmill's electronics if it is not properly designed and we still see poor designs in this respect
If you don't like getting popped or if your treadmill is shutting down or going crazy, there is a fix. You can ground yourself to keep the electricity from building up on your body.
We now have wrist grounding straps that can be reused and attach to the frame of the treadmill without causing any markings and do not require any permanent modification to your treadmill. You can find them in any online catalog by electronic sales by searching for Grounding Strap.
Thank in advance, sincerely. God bless you.
If you need further assistance, please contact us.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
SOURCE: Where is the saftey switch on the precor 9.45i
You are refering to Reed switch or Sensor switch or Speed Sensor? please indicate.
Some equipment can have the safety switch when you remove the Hood as security measure, for to avoid the machine goes on or Start ON .
Please specify.
sincerely.
Der Sir;
The power switch is failure , you must Change the switch. You must be shure the some wires is Not loose, otherwise the wires will be touching the carcase causing the spark inside. Retight the wires or solder .You must inspect the main motor board and all the element around . If someone is burned or other wires is touching the carcasing producing the spaprk.
ernesto cuadramanagua, nicaragua c.a.
