I can't find the reset button on my life fitness T7-0.
The treadmill is brand new and has not yet been used. I can go through the workout choices but then at the end it stays on please wait and is stuck. In the troubleshooting manual it says to press the reset switch which is under the right motor pan but I can't find it. Manual says that it is stuck in incline? But it's never been used. Thanks!
When necessary to immobilize the treadmill, set display to read SELECT A WORKOUT. (Press the STOP Key twice if not already there). Then hold down the SPEED DOWN Key and press the STOP Key. The treadmill now displays IMMOBILIZED. In this state, the treadmill cannot be operated. The main motor and incline are disabled. The treadmill will remain in this state across resets, power cycles, etc. To restore normal operation, repeat the same key sequence: hold down the SPEED DOWN Key and press the STOP Key. The treadmill will display SELECT A WORKOUT again.
see this step and fix it. God bless you
Unplug the treadmill. Locate the console key and place the
safety or reset key into the treadmill console. Replace any parts that
need replacing, or move on to the next step.
Locate the reset switch on the underside of the treadmill
console. Usually the button is large enough to trigger with a pencil
eraser or Q-tip. Plug the treadmill plug back into the wall. Use the
Q-tip to press the reset button. It may be necessary to hold the reset
button down for a few seconds. "CL11" will appear in the display of the
treadmill.
Press the reset button one more time with the Q-tip. "CL21"
should appear on the screen. Press the enter key. The display will
change again and show "CL22." Keep pressing the enter key until the
numbers cycle through to the number "CL26." Press enter one more time.
The letter E should appear on the display screen.
Press enter twice more. The letters "SS" should appear on
the screen. When this happens, press the start/stop key. Making sure to
keep well away from the tread, press enter to start the treadmill. The
treadmill will start on its own. The treadmill will stop on its own
after a few seconds. When it stops, press the power key two times.
Remove the safety key and put in a safe place. Your treadmill is reset.
Please go to the pag 48 from your user manual. If you do not have the user manual. go to the next web page: www.fitness.manualsonline.com and download for free, and follow the instruction for reset your wax bag device.
1) Weslo
Of all the Icon brands, Weslo treadmills are the least expensive, and in fact are typically the lowest priced of any treadmill regardless of manufacturer. They are entry-level machines intended for use by beginners and walkers that do not engage in a more demanding workout. They lack the power of more expensive brands and are built with smaller running areas. And warranties are typically no longer than 90 days.
In the Weslo line, the Weslo 400 CS treadmill sells for under $400. It is consistently picked as one of the top budget treadmill models.
2)Image
Image is another brand of treadmill produced by Icon Fitness. This line is slightly more expensive than Weslo, but is still considered a budget machine, typically selling for under $1000. Many experts feel that Image treadmills offer the best value for the average person. The only drawback is the warranty, which is only 90 days on many Image models.
The Image 1200 treadmill has a 2.0 hp continuous duty motor that provides a maximum speed of 10 mph. The platform can adjust to inclines from 0-10%. It is a great choice for those runners on a bit of a budget and for those who want to spend $1000 or less. The Image 10.6QL was ranked among the top five treadmills by U.S. Consumer Reports. It has six programmable workouts and also allows you to determine your speed and incline based on a heart rate monitor. It is IFIT compatible, which means you can connect to the Internet to access online workouts. It costs around $1400 and is folding for convenient storage.
3) Proform
Proform treadmills by Icon provide shoppers with perhaps the most comprehensive options in exercise equipment. Budget models start at $400 and the overwhelming selection continues up the spectrum to several mid priced models that fall in the $1000 to $2000 range. The Proform 795SL treadmill sells for under $1000 and is often a top pick among consumers and fitness experts. The LX 660 sells for under $600 and has plenty of features for a budget treadmill. Like many of the budget treadmills, Proforms often have a less than stellar warranty, typically 90 days.
4) NordicTrack
There are literally dozens of different NordicTrack treadmill models produced by Icon. They range in price from around $800 for a NordicTrack C1800 to $2000 for a 7500R model. Many fitness experts feel that consumers spend a bit more for the name brand when they purchase a Nordictrack treadmill. The machines often look very nice but may not always offer the best buy as some people have experienced problems with reliability. All models typically come with a heart rate monitor, but some of the less expensive models offer a 1.5 hp motor and a smaller platform, often around 50".
5) Reebok
Reebok treadmills also depend on name recognition to help attract buyers. Models often look nice and have plenty of features but have been known to be less durable than other brands. It is important to note that Reebok home treadmills are not made by the same company as the commercial models found in fitness clubs.
I have seen this a couple of times. The incline motor probably has a gear problem. Remove hood and find the plug for the incline motor, disconnect and then reset treadmill. treadmill should work but will not incline until incline motor is repaired or replaced. Good luck.
This error shows up if motor controller detects a failed part. This isn’t a reset-able error. Treadmill will not allow workouts until serviced. Solution Main motor wires/leads could be disconnected at the start of a workout. If the motor is properly connected and in working condition then the drive transistor could have failed. Check Motor Controller.
