1. With the dock station off (none of the functions are highlighted) press and holdthe Clock/display and/or Play/Pause button.
2. After holding for up to 5 seconds (still hold) press the hour or minute buttons to adjust th ehour and minute
3. Once you are done, release your the clock/display and/or play/pause button
THE SOLUTION IS TO PUSH AND HOLD THE DISPLAY BUTTON FOR 5-6 SECONDS...BUT...IT DOESN'T LOOK LIKE ANYTHING IS HAPPENING, SO YOU CAN SIT THERE AND HOLD IT ALL DAY...(this would be a great Candid Camera episode)....just hold the button down for 5 seconds and while still holding it, push the <<hour, or the minute<< buttons till you get the desired time.
SOURCE: alarm clock and time w/ clok smooth ipod system
According to the instructions that we received with our clock. You should be able to get the Instruction manual from [email protected]. It is also supposed to be under the support section of the website www.dpi-global.com but I couldn't find such a link.
However the "Operational Support" insert has the following:
Setting the clock
1. With the unit powered off, press and hold the "Clock/Display/Play/Pause Button" for at least 4 seconds.
2. While holding the "Clock/Display/Play/Pause Button", press the "Hour" and "Minute Buttons" to adjust the hour and minute on the time.
3. When the correct time is selected, release the "Clock/Display/Play/Pause Button" to set the clock
Setting the Alarms
1. With the unit powered off, press and hold the "AL1" or "AL2" Button for at least 4 seconds.
NOTE: An alarm icon will begin to flash on the LCD display.
2. While holding the "AL1" or "AL2" Button, press the "Hour" and "Minute Buttons" to adjust the hour and minute on the alarm time.
3. When the correct time is selected, release the "AL1" or "AL2" Button to set the clock.
4. Press the "AL1" or "AL2" Button consecutively to switch alarm one and alarm two between sounding to a buzzer, the currently set radio station, or a docked iPod.
I can't figure it out :(
I can't figure out how to set times or alarms :(
=[[[ this sucks
me too. :(
no manual. what to do
me too.!
we can't figure it out either....IS THERE ANYONE OUT THERE WHO KNOWS HOW TO SET THIS C-L-O-K!
