There is power to the oven. clock works, but everything else is not. Lights for oven and burners light up as if on
SOURCE: oven elements will not heat
Just a follow up report on aborcass's solution to the oven problem.
Just took delivery of the suggested part, removed old thermister and installed new part, back to the breaker and apply some juice to the circuit.
Turned on oven....BINGO!!!!!
Oven now is as hot as the wife would like it!!
Well done and well earned FixYa (already awarded)!!
Many thanks again
Steve, aka kf6wax
SOURCE: Oven not working
i think both of you have not set the clock correctly and oven is on automatic. get the book out and try again
SOURCE: TOP BURNERS WORK BUT OVEN DOES NOT WORK AT ALL.
Sounds like a heating element. Same thing happend to my oven. You can find them around 50-60 dollars. Veryy easy to install, just remove a couple of screws and remove old element and put in new one. Make sure you shut off power to oven firstg of course.
SOURCE: My GE Oven heating element and timer clock went
Try unplugging the oven and let sit for 10 min. This will reset the curcuit board and reboot the electronics. You may have to pull out the stove o get to the cord.
SOURCE: model FEFL78CBC frigidaire oven bottom (bake)
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
