One of 2 things can do this,first unplug the unit from the power if it continues to fill then its the water fill valve thats bad,second if it stops filling when unplugged from the power outlet then its probably a plugged pressure switch line from the tub so the water pressure cannot switch the pressure switch diaphram from fill to wash cycle,open the cover and remove the pressure hose from the tub and blow into it and you will hear a click in the pressure switch its connected to,then replace hose onto tub side and blow into the other end of this same hose and make sure theres air movement in the tub as you will see and hear bubbling noise
