hi remove your center jet could be same one that holds your bowl tight under the bowl and look for a small plugged up hole clear it open,,,,,, and it should **** fuel up and start and remain running
You can try buy a new spark plug and replace it with the old one. I had the same problem! You just have to keep pulling until it catches! Or maybe it's the carburetor that needs to be replaced! I had the same problem wih my scooter. I just changed the carburetor and it worked fine :)
Probably dead gas from sitting too long. Dump it out & put in fresh gas.Could have moisture in it. Pull out spark plug & crank it over several times after putting gas & let it sit a while to dry out or blow it out with compressed air. It should go.
Pull the spark plug out and give it a pull. It should pull VERY easily. You could have a vapor lock inside the cylinder and this will clear it. If it still doesn't pull easily with the plug removed then you've probably either bent the crank shaft or seized the engine, due to a lack of oil in it. Hope this helps. Best of luck. James
