I replaced the ink cartridges,but the screen show me ink empty.I use the recomended cartridges.I think that the problem is I delay time in replaced them.What can I do?
You may try this link:
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000300/000036/faq000336_002.html?reg=us&c=ca&lang=en&prod=mfc420cn_us&Cat=16
Here's another one:
http://welcome.solutions.brother.com/BSC/public/us/ca/en/faq/faq/000000/000400/000088/faq000488_006.html?reg=us&c=ca&lang=en&prod=mfc420cn_us&Cat=16
Please refer this link to get full information on how to replace the cartridges:
Replace my Brother MFC’s print cartridge
Thank you
First of all take the cartridge out. Make sure there is no dirt around the nozzle. Use a soft cloth to clean them. Then put the cartrdige back and turn on the printer. Now try printing. If it still shows cartridge empty but you can take prinout just restart the computer.
If cartridge still shows empty and you cannot take printout also in that case uninstall and reinstall the printer.
Thanks
Delaying in the replacing the cartridges does not cause this problem.
remove all the cartridges .shut off the printer .and then ON after 5 minutes.then reinsert all the cartridges properly.this will reset the printer and it will work fine.
for further help feel free to ask through comments.
Please perform the following:
1. Open the printer and remove all ink tanks.
2. Insert a single ink tank in the printer then close the cover.
3. Confirm whether the printer recognizes the installed tank properly. If it does, it will indicate it does not detect the other ink tanks, as they are not currently installed in the printer.
4. Repeat steps 1-3 with another ink tank.
5. If the printer at any time indicates two of the same ink tanks are installed, the cause will be the last tank installed. For example, if you inserted an ink tank earlier, and you later inserted another ink tank, and it said two of the same inks were installed, the cause of the issue is the last ink tank.
Check in bottom of the cartridge that plastic strip is not there.also shaked then refix properly.
check laos u put it in right ink tank color matching .
According to your problem first make sure that you have installed the cartridges properly. Go the the printer properties in control panel and follow the steps open the printinging preferences tab> maintainance tab > Ink cartridge replacement> then the window will show the process of the replacement of ink cartridge. Follow those steps of replacement. Then let the cartridge be processed, it will take a few time. And then your cartridge replacement will be finished. Then align the cartridges from the alignment option in printing preferences as well. If it doesn't solve your problem then the cartridges are faulty, replace a new set of cartridge is recomended.
