Is there an aftermarket bagger or a company that makes baggers, or is there another bagger that fit my Craftsman ZTS6000 the bagger that is supposed to fit is model #24921 or 1695283. Can only buy at SearsPartsDirect now and the price is exteremly high.
SOURCE: Why does the craftsman garden tractor model no.
I modified my John deere with a chute from another mower into my cart, It works great and picks up 10 times more trash than regular bags, you have to use the pick up blades, I just fill up the trailer, and dump the whole thing in the burn pile. Then go get some more. Believe me, i could run all day and not clean the whole yard. The pick up blades have some power but they do get clogged now and then, i just unhook it from the deck and dump it out and get going again. Hope this helps.
SOURCE: Cut grass clippings does not get picked up by riding lawnmower
When using a bagger, you need correct blades on mower or Worn blades will cause the deck not to get the vacuum needed for the bagger to pickup.
SOURCE: my craftsman riding mower model917.274641 won't start
First, take the air filter off and spray a shot of carb cleaner/ starting fluid in the carb. If it starts for a second and runs on the prime then its a fuel issue. Check fuel filter, fuel delivery, and carb.
