I recently purchased a Samsung HT-BD2R 7.1 Channel Blu-ray Home Theatre System and i would like to have the normal tv and the PS3 sound coming through the theatre system. Could you please tell what cable i would have to use to be able to do this.
If your television has RCA style audio/video output you can use an audio RCA cable (red & white connectors) and simply plug from the 'output' of your television into the auxilliary input on the back of the HT-BD2.
Then select AUX on the HT-BD2 remote, whenever you wish to listen to the television audio.
Connect the PS3 with HDMI to the Home theatre.
Connect the TV digital optical out put to the optical input cable of HT-BD2R provide your tv has a optical digital out put
You have the option of channeling the out put through either optical or HDMI in PS3.Go to the set up and set the audio out put to HDMI
• Is the remote control being operated within its operation range of angle and distance?
• Are the batteries exhausted?
• Have you selected the mode(TV/DVD) functions of the remote control (TV or DVD) correctly?
I have exactly that same problem, I'm sure it is probably simple but I am not so tech savy
Help me to turn on my blu ray player. I have plugged it in to AC plug, no response. It is connected to a Samsung TV and worked previously now nothing. Help?
