Kitchenaid stand mixer 5SSWH 325 watts. How do I adjust the bowl height? Beater is too far from bottom of bowl. Thanks! Cas
There is a screw at the bottom of the motor head (flat head) you usually can't see it because of the top rim of the mixing bowl. hard to see and hard to reach, it may also be hard to turn due to "gunk" from mixing stuff (egg butter flour sugar) turn the screw counter clockwise to lower the motor head clockwise to raise it, you may also have the wrong size beater, it is not an uncommon problem, if you are the original owner and you have the original beater it should fix your problem with the adjusting screw, however I am not clear as to your model a 5SSWH would actually be a K5SSWH, which stands for kitchenaid 5 quart solid state white mixer, if this is your model number and you have the correct beater size then the adjusting screw will work to lower the head down, adjust it down using the stir or slowest speed just untill you can hear the beater "Ding" against the bottom of the bowl, then back it off a quarter turn to adjust properly. Hope this helps, let us know
