Your router access password or wireless password. Login into you router using your browser (connected by a LAN cable) and under the wireless section you should see the network password.
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
SOURCE: HOW TO ACCESS DLINK WIFI ROUTER BECAUSE OF FORGOTEN PASSWORD
You reset the D-Link back to the factory default by - Press the RESET button at the back of the wireless router when it is powered up. Holt the RESET button foe at least 5 secs until the LEDs flash and then release the RESET button.
You can then configure the D-Link as follows ;-
To set-up and secure the wireless router from unauthorized access, follow these steps: -
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL IP address.
3. Enter the router setup, login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WPA2 (if not then WPA).
7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
We have a Dlink 615 Wifi Router,I couldn't set a username and password to prevent it from illegal usage.We have a cisco 1700 router. Can any one help us in installing a username and pass word for our router.
Get online
and got to www.google.com In the google search box type: "Dlink
Support" (without the quotes and put your manufacturer name before Support).
Look for downloads and drivers. Enter your model number and operating
system when requested. Look for Manuals.
The IP address to put in your browser to get into the router is: 192.168.0.1
The default userid is: admin
There is not default password, so leave it blank.
