Question about Sony Televison & Video
Dvd player has no voices, music, backgrond, hooked up to multiple speakers
When I play movies it has background sound, music, but voices are hardly audible
    Top Expert:
  • Sony Master
  • 76,099 Answers
Check the inter connections. Wire break might be the reason.
Posted on Jun 03, 2012
SOURCE:
Agent Jason
  • 78 Answers
SOURCE: I have a Pioneer DV
Hi edwardm1,
If you are only hearing part of the audio from your DVD player, I would suggest you check your audio settings before seeking repairs.
Audio can be encoded to a DVD in several ways. If the audio on the disc is different than the settings on your DVD player, you may not hear all of the audio layers. For example, if your DVD is encoded in 5.1 Surround Sound, but your DVD player is set only to play basic Stereo, you may only hear portions of the audio.
Try accessing the menu on your DVD player, and look for the audio settings. If there is a higher setting available than is currently selected, try a higher audio setting. A higher setting should also be compatible with lower types of audio encoding.
If this does not improve your audio, or if you need help navigating your product menus, I would recommend giving Pioneer's toll-free support line a call at (800) 421-1404.
Thank you,
Jason,
Go Ahead. Use Us.
Posted on Jun 13, 2008
Agent Jon
  • 100 Answers
SOURCE: emerson dvd player - background sound lauder than dialogue
Greetings surfjax,
If you will allow me to make an assumption, you do not have a 5.1 surround system connected to your DVD player. This is a common experience with users of a standard TV or stereo receiver if a movie is being presented in 5.1.
In a surround sound system the center channel speaker provides almost all the vocal tracks while the side channels will provide music and some background noises. You'll still be able to hear the voices in your side speakers, but it will be muted and over powered by music or sound effects.
Some DVD players allow you to "Downmix" the surround signal to stereo. You might want to look around your sound setup on the DVD player or check your owners manual.
Hope this helps.
Jon
Go Ahead. Use Us.
Posted on May 22, 2008
welcomejee
  • 10594 Answers
SOURCE: My DVD player will only play background sound not voices
Go to sound menu of dvd player and select Stereo sound and if surround is enabled, disable it.
You can get help from user manual of dvd player.
Posted on Nov 09, 2008
bob_computer
  • 3153 Answers
SOURCE: Sudden problem: voices can't be heard, everything else normal.
If this is on a home made dvd then that is probably where you the problem is.
If you try a proper store bought dvd and that works then you know its the other dvd.
But if a proper store bought dvd give the same errors then it could b a setting or part of the sound replay circuits that have or ore dying
Posted on Aug 17, 2009
redlycan
  • 52 Answers
SOURCE: i can't hear the voices when i play dvds
Change your audio setup to stereo. if you are running two speakers
Posted on Sep 16, 2009
Pioneer VSX-D509S 5.1- No voice audio on DVDs
try the dvd player settings to bitstream out in setting menu ok not pcm best to use coxal cable to get fiull 5.1 suround
Jan 20, 2008 | Pioneer VSX-D509S Receiver
Only background sound, no dialogue when playing blu ray
do you have a center channel speaker hooked up? Most dialogue in movies should come from the center channel.
Feb 28, 2014 | Onkyo TX-SR605 Receiver
Bluray player can't hear voices but background music
Either the player or the set it is hooked to may have in the audio settings a "Hall" or similar setting--background will be louder than people speaking---its a setting.
What is brand of TV? (Toshiba?)
May 16, 2012 | Samsung BD-P1500 Blu-Ray Player
No English language on DVD 's
Bought a new unit. The old unit was a surround sound system in which the previous owner removed the speakers. I wasn't aware of the problem but found out that it would not allow it to play on Dolby 5.1...It would only play DVD's on channel 2, therefore no english etc. Thanks for your help!!!
Feb 10, 2010 | Koss KS4110 DVD Player
My panasonic dvd player is not playing the sound of the main character's voices on two diff. dvd's. Background noise and music is fine. The disks work on another dvd player, and other disks have no problem...
You are listening to a Dolby Digital source and you either don't have a center speaker hooked up or, it's not enabled. If you only have 2 speakers connected to a surround receiver, switch your receiver from surround to surround off. If this doesn't work, or you need more help, specify your system and how it's all hooked up.
May 03, 2009 | Televison & Video
DVD plays partial sound
Check your speaker connections it sounds like you have a 5.1 or higher sound system. 5.1 means left front speaker, right front speaker, center speaker, right rear speaker, left rear speaker and subwoofer.
Voices in movies all get channeled to the center speaker (you can usually hear it a bit from the right and left front speakers as well). If your center speaker is disconnected or not working, you will only hear the background sounds.
Sep 20, 2008 | Compaq Presario 5000 PC Desktop
Emerson dvd player - background sound lauder than dialogue
Greetings surfjax,
Hope this helps.
Jon
Go Ahead. Use Us.
May 22, 2008 | Emerson EWD7003 DVD Player
Jensen VM9510 No voices in movies
It sounds as though the unit is set up for "6-channel" surround mode, but you don't have a center speaker. That means the audio sent to that speaker isn't being heard. You'll need to get to the audio setup menu, and either turn off the 6-channel mode, or turn off the center channel option. There are two different Jensen models with the VM9510 model number, but you can download an owner's manual for either one here: http://www.audiovox.com/webapp/wcs/stores/servlet/GenProductListCmd?type=model&catalogId=10001&storeId=10001&categoryId=VM9510&langId=-1&page=&urlString=&productId=&brand=
Jul 02, 2007 | Jensen VM9510 Car DVD Player
No sound
Sounds to me like your center speaker is either not connected, or somehow not working. The not working part could be explained by a failed speaker or, possibly a failed amp in the unit.
Mar 11, 2007 | JVC TH-M505 System
Televison & Video Logo
155 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
