Making a batch of popcorn the unit got warm. tried to start the micro wave to make more popcorn then did not start keypad, clock, cook time select, interior light work fine. when cooking time selection is made and "start" button is pressed the timer countdown starts, but no heating (no sound of the magnetron) or turntable operation. took out the microwave to get to the fuses but unsure which fuse I am looking for and unable to open cover because of some real specialized screw heads.
SOURCE: Ge Spacemaker microwave jvm240 wv Micro hood combo.
sounds to me like the magnatron has shorted out. i don't know of a way to test them unless you have some high dollar equipment. a continuity test prob wont tell you anything. what reading did you get on the cap when you tested it?
SOURCE: JVM1190 wont cook
You have a blown actuator. This is the device that creates the microwaves that cook the food. The cost of one of these will be as much as a new unit.
SOURCE: Ge microwave model JVM1190WY buttons work but does not cook
The problem you are having with your microwave is a common one. Not heating is a problem that can be caused by three things. I'll list the most common solution first, the magnetron that actually does the heating is what is making that noise and has gone bad. It is possible for you to also have a bad high voltage diode that has opened up, solution two, or solution three is the high voltage capacitor is not working properly as well. From my experience with microwaves I am positive that it is your magnetron that is bad. If you are not do it yourselfer you'll need to take it to a repair shop to replace. However, if you know how to use a screwdriver and can unplug a couple of wires with spade terminals on them, then you can take it off yourself, find another one and replace it the same way you took it off. The magnetron sits behind the control panel of your microwave but on top. It has cooling fins on it and has 2 terminals maybe three depending and make and model that plug into it. It has 4 screws that are easy to get to that actually holds it in place. If you do not have a good local source like an electronic parts supply place then you can find the right magnetron at www.mwoparts.com. Be sure you always unplug the microwave before touching or trying to take the he cover off and then when you take the magnetron off also.Good luck and God bless.
SOURCE: Microwave doesn't work
Sounds like you have a faulty control panel. I would use a meter and test the power from the control board to the magnetron and circuit board. Chances are the control panel is faulty
SOURCE: I have a GE SpacesaverXL
I wouldn't worry about the sensor error right away.
Sometimes that's just caused when the door is opened before steam could
be detected or steam was not detected in the maximum amount of time.
Once it's all working again, if you still get the error regularly, it may be a bad humidity sensor.
If the internal cooling fan IS running when you try to cook AND the oven is not heating, it's probably a failed secondary interlock relay on the control circuit board.
If the internal cooling fan is NOT running when you try to cook AND it's not heating, the bottom door switch is probably the culprit.
Here's is a file on checking and replacing door switches.
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are working.
Listen to that very carefully, and listen to yours to see if the cooling fan is working.
When I say internal
cooling fan, I do not mean the hood vent exhaust fan which you can turn
on and off manually.
I'm instead talking
about the internal fan which comes on automatically whenever you
microwave.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating components.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Let me know if I can help you further.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
