Great water pressure, as I tested it as it goes into the machine and checked/cleaned the hose filter as well, but the standard cycle takes over 2 and a half hours to complete?Great water pressure, as I tested it as it goes into the machine and checked/cleaned the hose filter as well, but the standard cycle takes over 2 and a half hours to complete?
Are you on a well? I so, you may have dirt build-up on the inlet screens inside the inlet valve body. Take the hoses off the back and check for dirt in those screens. If not, you may have an inlet valve (solenoid) issue; the valve may not be opening all the way, constricting the water flow.Are you on a well? I so, you may have dirt build-up on the inlet screens inside the inlet valve body. Take the hoses off the back and check for dirt in those screens. If not, you may have an inlet valve (solenoid) issue; the valve may not be opening all the way, constricting the water flow.
You can't post conmments that contain an email address.
Toilet tank won't fill up or is slow to fill. The most common reasons for a valve to slow down or no longer fill the tank after the flush are debris issues and the length of time a valve has been in use. ... Valves in use for a period of 7 years or more can have their working parts start to wear out. 1.
https://www.fluidmaster.com/toilet-problems/remove-fill-valve-cap-replace-seal-toilet-wont-fill-slowly-filling-tank/
replace the guts first,with universal ones,5 bucks at walmart,what happens is calcium builds up inside them and slowly closes the fill hole,just like your shower head,its easy to install the new "guts", Fluidmaster Universal Fill Valve 400ARP25 The Home Depot
Valve fully open on inlet going into toilet if it is then fill valve needs to be replaced check water line for any abstructions that might interfere with water going into tank.
Any Roundup Weed & Grass Killer RTU can be refilled with the new 1.25 gallon Roundup Weed & Grass RTU Refill bottle OR use Roundup Super Concentrate (purple cap).
Directions to Refill with Roundup Super Concentrate
24oz RTU: 1 oz of RoundUp Super Concentrate, fill with water very slowly to avoid foaming.
1/2 Gallon RTU: 2 1/2 fl. oz. of Roundup Super Concentrate and slowly add 1/2 gallon of water
1 or 1.1 Gallon RTU: 5 oz RoundUp Super Concentrate, fill slowly with 1 gallon of water
1.33 Gallon (PNS & PNG): Add 6.5 fl oz of the Super Concentrate to container and slowly fill with water
Slowly fill the water tank with water. The stink bug should rise to the surface. Continue filling slowly and the flow of the water out of the fill hole should force the stink bug out! Remember as you're filling you must use something that will NOT block the fill hole or the water cannot drain and your "little friend" won't be able to be flushed out by the flow of the water.
I hope this helps!
It sound like you have debris caught in the fill valve. Remove the top where the washer is and put your hand over it and slowly turn the water on to flush the fill valve. Replace the washer with a new one and then replace the top.
If you have the old ball and **** style, replaceing the diaphram is harder so I would recommend replacing it with a fluidmaster fill valve. Hope this helps.
