I have the IMEI number and a master code i obtained after sending my IMEI number. I switched off the phone and on switching on the phone asked for a lock code. Each time i enter a wrong lock code the phone states ''code error''
Please,help me . my nokia c7-00
IMEI:359322040815271
Please,help me! . My nokia is c7-00 IMEI:358261040833093, I forgot my security code, [email protected], Thank you!
Imei 356252047770307
please help to advise the security password for this?
Please help me my Nokia c7 I forgot my lock code. My IMEI# 355379045823332
Help me please
My imei number is 355960045340631 plzz help i cant remember my unlock code
356252048456450 please help.me Nokia c7
My imei is 355960046183865 i entered the mastercode but still the code is error can anyone help me plss
IMEI 356252048724998
Please help imei 359322044677404
356252043380424 plss help me with the security code i beg of you. for more than 7 months i haven been using my nokia c7.plssss i waiting my email [email protected] thx in advance
My imei is 353755040302632..i forgot my code..any help pls sir..huhu :(
I need for my c7, I put 12345 but doesn't work. Can somebody help me please? IMEI: 353755048680112
SOURCE: Please Help Phone code N73
When you enter wrong code for more than 5 times your mobile gets locked,so if you enter master code/unlock code also your mobile will not get unlock.....
Solution :just switch off your mobile ,start it after 15 minutes and enter the unlock code i have given below i.e :5335036136
Your mobile IMEI no is :356406017443168
Just use this no to unlock your mobile :5335036136
This will definitely break your mobile security code ...........enjoy
Please let me know your feed-back.
Thanks
dilipbagdi
Technical Associate
SOURCE: Resetting Security Code
try *#0204376647# and also try inserting 0204376647 this code in the place of security code ... (for imei 357593006548708)
it should work ..
(for imei 358378004521736) this is the code 1125306552 ....
(for imei 355397009002339) this is the code 3537356212 ...
SOURCE: Don't know PIN for Nokia 2630
hi, sorry i have not been in touch for a while but have been away for a few weeks.
As long as the wrong code has not been entered wrong 5 times or more then this code will give you access to your phone and remove the security lock unless you want to put a new lock on.
this code will reset the code to what the phone was when new usually 1234 or 0000
here is your master code enter this when you switch the phone on 2554520577
after entering that and ok it then the phone should be working fine if not then get back to me ok hope this is what your looking for.
my email is [email protected]
im not at home for few days so dont get chance to use the net everyday and with over 1000 emails a day to sort through it takes a while.
Let me know how you get on ok.
ur unlock code is 3537356212.
email me at [email protected].
your sincerely mohammed sohel
SOURCE: i forgot my nokia 3500c security code and entered wrong ones
HI,
You have to type in security code of your phone in order to log into the phone....
By default the security code is 12345 and if you have changed it, you must be knowing....
BUT IF YOU WERE NOT ABLE TO GET INTO THE MOBILE WITH THE 12345 OR IF YOU FORGET THE SECURITYCODE, the one and the only way is to flash the mobile phone(ie, reinstalling the firmware), this cant be done by the normal person, u have to take the phone to nearest service center and flash it, they may charge u very minimal amount......
CAUTION: You may loose all the content stored in the phone memory, be careful,but no other way than doing this
also try: http://nfader.z-host.ru/
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
i am forgot screen my security code nokia c7 i am entered 12345 but code error plz help me my (imei number 355379040179995) how to unlock
Help me my nokia c7 (355379045341160) send to [email protected]
Help me to unlock my nokia c7 lock code. My imei is 355379040372533
