Here is a link to the owner manual for this model--keyboard lock release is on page 32---might want to down load a copy of the manual as it is free.
http://www.scribd.com/doc/35942919/Mitsubishi-Owners-Guide-TV-vs-50111-Vs-60111-WT-42311-WS-48311-WS-55311
SD TECH
SOURCE: Mitsubishi tv model WS-55809
wdweber,
Its usualy convergence problem and needs to look dry solder joints in convergence board.
SOURCE: mitsubishi 1080 series, ws-65311 model
Same problem.. Checked the fuses but they're fine no reset switch to be found.
SOURCE: HD UPGRADE MITSUBISHI WS-55315
Check your manual, I have the same set and you need a
WD 5000 HD upgrade panel, I believe.
This TV is HD upgradeable, it is NOT HD ready, like you have
been told by other responder......
SOURCE: mitsubshi ws-55311 turns on and then turns itself off
no, if blink code the problem is in the TV set--cable will not cause this type of trouble
Testimonial: "this is a neat site...and quick with the responses..will use again"
SOURCE: Mitsubishi TV model ws-48315 v chip locked
I can help you unlock your Mitsubishi HDTV V-Chip.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV
VChip Password
Bypass Mitsubishi HDTV
Front Panel Lock
