WHEN WE DO THIS WE CAN GET SOUND BUT NO PICTURE. WHEN WE TRY TO AUTO PROGRAM CHANNELS IT SEEMS LIKE THE TV WON'T PROGRAM THEM. WE HOOKED THE CABLE UP TO DIFFERENT TV EVERYTHING OK. WHEN WE DO THIS WE CAN SEE THE PROGRAM NUMBERS JUST FINE. BUT NO PICTURE JUST FUZZY WHITE SCREEN AFTER PROGRAMING COMPLETE.
Check tv is set to pal or ntsc....it has to be the same as the output if the box.Then check the connections...have you a different hdmi lead as sometimes the lead is the wrong class....also try a different output slot or input slot to tv....change the av input or tv menu....do not use the tv to tune the box...you need to set the tv to the right av input for the box...then use the box menu to tune the box.....finally if the picture is still snowy then it has to be the dish alignment...or the cable between the dish and box connections is not tight enough.
SOURCE: Mitsubishi VS-5041 (TV turns on but no pic or sound)
Your problem is one and or 2 differant problems. The power regulator could have went bad because of the convergence IC have shorted. Seen this a thousand(easy that!)Times. All parts in this set are soldered in and are not user serviceable. look in your owners manual or call 800-332-2119 to get an authorized servicer to come and look at your problem . I wish i could tell you what to replace but theres the Extreme Hi voltage inside these sets even when they are not plugged in .. Good Luck
SOURCE: Mitsubishi VS-45607 Picture flickers and dims
It could be a bad solder connection that opens up as the set warms up. It could also be caused by a couple of bad capacitors, C2p05 (100uf/16v) Located By Ic2p01 and check C2c52 (10uf/50v) Located near Q2c51. A technican will be able to fix it for about what you paid for it I suppose.
SOURCE: Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
SOURCE: Mitsubishi vs 5051 rear projection tv sound but no picture
No video but good audio Mitsubishi VS5051. Check R509 and R 519, 100 ohm resistors located on the main PCB near the flyback transformer. Also bad connections on any of the yokes and the vertical output IC will cause the same problem.
SOURCE: No sound on some channels
Check in the menu to see if the audio is on SAP. If it is change it to Stereo. Hope this helps
