Flame is burning yellow. Adjusted air vent w/no change in flame.
SOURCE: Low flame burning on CharmGlow 4-burner gas grill,
check burners are not bolcked check orffice is not blocked also check reg is giving right pressure
SOURCE: Brickmann 6440 Side burner puts out a good flame.
Reduction in flame as more burners are turned on is usually a sign that the regulator is going bad, try replacing the hose and regulator.
SOURCE: Turkey fryer is burning rich
first check the gas regulator is the presher right? then try cleaning out all the pipe work and the burner jets i bet you have a dead spider stuck in the gas pipe as it enters the burners,,this would upset the air to gas mix,,so its running on a rich gas mix
SOURCE: Flame has become very yellow and lazy. I installed a new regulator, but didn't help.
try cleaning the burners sounds like they are blocked ,yellow and lazy is lack of air to burn
