Microsoft Windows XP Home Edition Logo
Posted on Nov 27, 2008
How do i export data from excell to myob i have the 2003 microsof
I'm trying to export financial data from excell to myob
Ofer Agady
Level 1:
  • Contributor 30 Answers
  • Posted on Nov 28, 2008
Ofer Agady
Contributor
Level 1:
Answers
30
Questions
0
Helped
6888
Points
49
You are going to do the opposite.
Not exporting from excell to myob but to import data of excell from myob)
You might need to save your excell data as an older office 2000 or office 97 version or even comma or tab sepperated file so myob could read it, it depends on your myob version and if it possible.
Thank you for using agadycom.
1helpful
How can I immigrate input data from computer to laptop, from MYOB Accounting to MYOB Accounting Plus
Moving to a new computer, and then do an online upgrade on the new one,
Setting up AccountRight on a new computer
MYOB https://help.myob.com > wiki > display > Setting+up+...
Nov 24, 2021 - Using AccountRight offline · Create a backup of your company file. · Copy the backup file onto an external storage device, like a USB drive. · ( ...
Moving AccountRight v19 to a new computer
MYOB https://help.myob.com > wiki > display > supar > Mov...
Feb 18, 2021 - Right-click your AccountRight installation folder and choose Paste. Choose to Replace the files in the destination. Once you're done, that's it!
Transfering data from one computer to another
MYOB Community https://community.myob.com > td-p
All you need to do is login to your my.myob and download the software. Once downloaded you can login to you MYOB data file the same as normal. If you are using ...
Solved: Transferring MYOB to new computer
Solved: Hi! I would like to transfer two different MYOB programs to my new computer but I no longer have the installation disk. One of the versions.
Moving AccountRight to a new computer
MYOB Community https://community.myob.com > Tips-and-Tricks > td-p
Need to move your AccountRight software to a new computer but your just not sure how? We have a step-by-step guide to assist you with the change,
Transfer file from one computer to another
Therefore we want to transfer all the data as well as the software to another computer, or to an online accessible myob software. Would you recommend how? 0 ...
Upgrading The Software Package
Upgrading from MYOB Accounting Plus V17
Solved: Hi, I have been using Accounting Plus v17 for 13 years and would like to upgrade from it. What MYOB software do I need in order to upgrade.
Enter transactions for closed financial year
Do a backup before you try this.
Go to File - Start a New Year - Start a New Financial Year. Continue through the next few screens until you see the Current financial year and a box showing the New Financial Year. Say your current financial year is 2013 and the New Financial Year shows as 2014. Change this to 2012 and then continue through the screens til the end. Then check your financial year under Setup - Company Information, you will find it now shows 2012. Enter the transactions you need, then go through the process again to change to 2013.
This is an undocumented feature un-supported by MYOB. Try with caution - not aware of any serious consequences but a few I know have done this.
Changing your system date and opening MYOB is a sure fire way to get locked out. MYOB records the date each time you open it. If the date goes backwards, it locks you out. Part of their protection.
9helpful
3answers
Export tally data to excel
tally data to excel converting . i have some data export to excel but no excel formating you have some tally data to excel spred sheet software
HOW TO POST PAST YEAR ENTRIES INTO MYOB
You would have to post the entry as last financial year, just to keep it all ligit. After you have done so check that your retained years earnings are correct!.
Printing previous reports in MYOB
save file into a .ZIP file then un Zip the file and it should help to change things or print reports. BUT, ALWAYS BACK UP A COPY OF YOUR FILE FIRST.
How to export table in ms access to excel
yes you can export your access data into excel, follow steps on how to export.
1. open your access database
2. open the table data you to export
3. under table data view click tools menu
4. select analyze
5. select ms excel
6. this will open your seleted access table in excel
hope this will help you..
2answers
Import data from access into excel where one column go into one worksheet and other into next
Can't be done.
Access will only put the data into one worksheet. It is very picky when it comes to exporting data into an Excel spreadsheet.
There are two ways to get around it:
1) You can export the data from Access into two files. One for the the first worksheet and another file for the second workshet.
2) You can import everything into one spreadsheet and build a macro into Excel to cut the information one spreadsheet and paste it into the other if this is a redundant task to do all the time.
Hope that helps you out.
9helpful
4answers
How can i export tally data to excel format?
Export to Excel With new release now you would get one more options while exporting data. One added format option is Excel format. excelexport.jpgIf you export in this format then file would be saved in xls format. More over if you put Excel formating option to Yes then tally would automatically format the data in presentable format. Tally would automatically bold the headlines and main fields for you and format data in a good way. Take a look at excel snapshot of balance sheet exported from Tally.
excelexport2.jpgThe special thing here is that you can do the calculation on any amount figure or any row or column, which was earlier not possible. The only drawback which i could find was that amount figures are not right aligned which is must for numbers for easy calculation, although you can do it by selecting the amount figures and putting them right aligned.
180helpful
15answers
Export tally data to excel format
Select ASCII. Give output file name Eg:d:/exp Open the file using EXcel.Select Delimite  nexxt comma finish.Export is completed
Excel not importing dates as given by accounting package
Dear Valanti,
This implies that basically the versions are causing the problem and there are compatibility issues with your program. I would suggest that you should copy the report files to a detachable media and transfer it to your new system because this is a one time process.
You can also install the same version on both PCs. You can also do following for tracking changes in documents:
  • In Word 2002 and 2003: Tools > Track Changes.
  • In Word 2000 and earlier versions: Tools > Track Changes > Highlight Changes. Tick Track Changes while editing.
If that was helpful, please press solved.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
