Question about NorStar Startalk Flash 2 Phone
Loss electric now line 1 is stuck
Power light is on main unit but not on star flash unit? Line one no dial tone, line 2 dial tone is good? How do you reset unit? Verizon says phone lines in are good. Problem is with system.
6ya staff
SOURCE:
Eugene Merritt
  • 298 Answers
SOURCE: Meridian M8X24-DS System Problem - All handsets are blinking on all lines
Sounds like a defective software cartridge
try a swap and see if flashing stops
Posted on Nov 26, 2007
mark hudson
  • 326 Answers
SOURCE: I would like Line 6 on Norstar System to Ring Different
Normal 0 To Change your Ring Type:
1. Press the Feature button, then * 6
2. Press the number keys 1 – 4 to hear the different ring types
3. Press the OK softkey when you hear your desired ring
Posted on Jan 16, 2009
Anonymous
  • 4 Answers
SOURCE: No dial tone on receiver only on voice
make shure handset cord is Not pluged in to the Headset jack on the bottom, needs to be in the handset jack (look at the icons)
Posted on Jan 30, 2009
ynotphone
ynotphone
  • 192 Answers
SOURCE: M7310 - 3 phone set system - line 3 on one set does no ring tone
Feature * 6 is for the ring tone of the set, it doesn't change the cadence (ring tone) on a line...
The only way to change the ring tone on a line... it would require everyone that has that number to change.
You need to go into the programming
-> look for LINE and enter
-> put in 003 for line 3 and enter
-> under TRUNK/LINE DATA find DISTINCT RING and change
-> REL to end programming...
Now that line 3 will ring differently. But it will ring differently on everyone's sets that has line 3 on their phone
Posted on Mar 20, 2009
computer_cod
  • 18 Answers
SOURCE: Nortel M7310 Phone moved to another jack, now no incoming calls
The reason your phones config is not the same as before is because configuration goes by what extension it is. So if you plug your phone in somewhere else, unless you have DN's configured, your extension changes, so say it was extension 21, but now that you moved it, its now 23, those settings remain on extention 21, so if you bought another phone and plugged it into were extention 21 is, it would have the settings that your old phone had before
To access the intercom by just picking up the handset, Press Feature **CONFIG (266344), Select <A. Configuration>, then go to <2. Line Access>, Select that and enter the extension of the phone you want to have access intercom by just picking up the handset. Scroll until you see <Intercom Keys: #,> make sure you have at least one intercom key. Then scroll until you see <Prime Line: #>, Press change until the display reads <Prime Line:I/C>  And there you go. Hope i didn't confuse you
Posted on Oct 02, 2009
Phone not working
Hi Pam,
Try these..1...remove your telephone line from base unit and fix it into a working land phone and check whether is it having normal dial tone.If it's having engage tone(beep beep...)remove paralleled phones and re connect to cordless base unit.
2.If line is ok (normal dial tone with full volume) & still display indicates line is busy, your main base unit must be having faulty components inside.Commonly these defects happen in thundering or surges through telephone lines.You have to take full set to a repair shop.
Rana.
Dec 28, 2013 | Gigaset As300 Twin Dect Cordless Phone -...
My phone doesn't have dial tone. Each time I dial a number and try to call,it wont work. I call my phone but it wont ring. I need help on this. What happen to the phone? Or what should I do?
If you have another phone connect it to the wall outlet to see if you get a dial tone. This will indicate if your base unit is faulty.
Check the power adapter to the base unit, make sure it is getting mains power.
If the base unit has dual phone lines and if line 1 is only connected and the line 2 has beed selected then you cannot get a dial tone. In the chase press the line 1 to get a dial tone.
If your base unit has only one line then check the phone line at the wall socket make sure it is plugged in tight, also check the the connection at the base unit.
If this does not work then ring the phone company and get the to test your phone line, you may have a faulty line to your home.
Feb 03, 2012 | AT&T E2116 2.4 GHz Cordless Phone
The phone lights up when put to charge also the red light on the base,, but when the phone line is connected it wont work ..What do u think is the problem?
The battery in the handset could be bad . First I would test that the base unit is recieving dial tone by pressing speaker button on base unit. If there is dial tone then problem is in handset or in base unit communication to handset. Try resetting power to base unit. Check manual for any re-initialization procedure. If the base unit is not receiving dial tone then I would test that the phone line is delivering dial tone to the base unit by connecting a known good phone to the line cord. If the dial tone is not present , problem could be in line cord from outlet, outlet, building wiring, or service provider.
Dec 08, 2010 | Uniden Cordless Phone
Base unit line 1 is flashing no dial tone
We followed your instructions and are not sure what worked, however, this AM phone line is working.
Sep 30, 2008 | Uniden Cordless phone EXS9950
RCA Phone model 252025 - displays Answer... on line 1
The Thomson folks said to reset the phone. Here's how: unplug power, then the phone line, then remove the batteries. Wait 10-15 minutes. Replace the batteries, then the phone line and finally, the power.
Note: We have 2 phones with these two lines and had to reset both of them to clear the "busy" on Line 1.
Sep 05, 2008 | RCA 25205RE1 Phone
How to switch phone to tone
I found a manual from AT&T that had the information I needed. Thanks!
Sep 18, 2007 | GE 26920 Cordless Phone
My intercom button flashed red to green. When I push a line button, I get a two-tone beep but no dial tone. I changed the internal 9 v battery. I unplugged the phone and waited, then plugged it back in....
Each telephone must be connected to line 1 and line 2 for
proper operation. The remaining lines 3 and 4 may — or may not —
be connected to each station as you desire. First plug in the battery, then the phone lines (1 & 2 are mandatory), and third the power cord. If your intercome LED is blinking red and green, then press: STORE IN, followed by "INTERCOM" followed by a free intercom# (i.e., any of the memory buttons 1 through 16 not already assigned to another telephone set). Then wait for the phone to go through its initiation sequence during which it searches each of the four possible lines. After that concludes, you should get dial tone on your active lines. :-) Marco
Aug 29, 2007 | GE 2-9450C Corded Phone
No Dial tone
Have you had an electric storm or power failure? A power surge can cause no dial tone also. It can be the main PCB in the machine or NCU PCB(board for phone cord). Unplug the machine from the wall, put your finger on the menu key first, plug the machine while holding the menu key, the light will flash and display will say maintenance. Press number 82, if there is a DF error the main board will need to replaced. The main board is the brain of the machine and is one of the most expensive parts of the unit. It is hard to distinguish if it is the modem or the main board on this unit that is causing the unit not to have a dial tone. It may be better to take it to a service center.
Aug 15, 2007 | Brother 2440C Colour Plain Paper Inkjet...
There was a power surge, and now my phone is stuck on pulse dialing, how do I get it back to tone? I can use the star key to bypass the pulse and put the phone on tone, but it only works one call at a...
You’ll need either a 6-button or a 24-button set SPIRIT CS administration.
First the control unit ADMIN switch must be ON, the administration overlay must be in place on station 10, and the set must be plugged into control unit jack 10 (call processing is interrupted only at station 10).
After moving the admin switch, and before dialing Ftr 7 -
From station 10 press intercom,
Press speaker,
Dial *0,
Dial 1,
Then Press Ftr 7.
Each line indicator light will show the current dialing type for that line. If the light is OFF, that line is set for touch tone dialing. If the light is ON, the line is set for dial pulse
dialing.
To change the dialing type for a line or lines, press the line button(s) and dial the
appropriate digit from the table below. You may press more than one line button to make the change on more than one line. If you enter a digit without first pressing a line button you will hear the error tone.
Be sure to turn the admin switch back off when you’re finished.
Mar 07, 2007 | AT&T Spirit 6-Button Stard Misty Phone
No dial tone on handsets
Hey.. Did you check to see if the phone is registered correctly ???
Jan 09, 2007 | Olympia CDP 24201 Cordless Phone
NorStar Startalk Flash 2 Phone Logo
42 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
pbxinc
martin hogg
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
