RIM Blackberry Curve 8900 Smartphone Logo
sofia Posted on Jun 01, 2012
My blackberry isnt charging?!please help!
My blackberry is not charging!!?,i have replaced the battery and tried different sockets throughout my house,but whenever i plug it in,it makes a short buzzing sound?
  • sofia Jun 02, 2012
    no light comes on
4 Related Answers
Anonymous
  • Posted on Dec 15, 2009
SOURCE: blackberry storm charging problem is plugged into the computer to
I've had this problem just since the last software upgrade. New charger, cable & battery haven't solved it.
spyroshima
Spyro Matiatos
  • 210 Answers
  • Posted on Jan 14, 2011
SOURCE: My blackberry torch will not
If you are certain the batteries were charged, the cord/charger should have turned it on. If not the solder points of the mini usb have come loose. Had that problem twice. Its common if you use your phone while its still conected to the cord
saad abdeen
  • 167 Answers
  • Posted on Aug 12, 2011
SOURCE: My Blackberry 9530 shows that
your Blackberry 9530 have hardware problem it has charging jumper problem repair it from any repairing shop
Anonymous
  • 380 Answers
  • Posted on Feb 24, 2012
SOURCE: bb bold wont charge
Welcome to the BlackBerry Support Community Forums.
Have you tried plugging the BlackBerry is different outlets or tried a different USB cord?
Does the BlackBerry show a charging symbol or is the LED flashing red or green?
I look forward to your reply.
Unable to Charge
Hey there,
This symbol generally appears when you are connected with a charger not suited specifically to your blackberry. the connector may fit the socket on the phone but does not work at the level the blackberry requires to charge. Try another cord made for the blackberry.
Also remove the battery from the device and ensure all the connection points are dust free. I don't think this relates to your problem, but a good idea to do from time to time anyway.
Good luck.
Blackberry won't charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
1helpful
Bb bold wont charge
2answers
Blackberry model 9530 battery wont charge
You may want to try a different battery or even try a different charger. If that doesnt work you will need to contact your service provider for replacement options.
Mar 03, 2010 • Cell Phones
2helpful
Red led is blinking and i cant tur on the telephone I already atake the battery off and still the problemm,need help
Hi please do a hard reset on the BlackBerry smartphone.
1) Remove the battery cover from the back of the BlackBerry smartphone.
2) Remove the battery, and then reinsert it after a few seconds.
3) Replace the battery cover.
If the display is still not working, verify that the battery is charged by trying it in a different BlackBerry smartphone.
If the battery is working, download the latest BlackBerry Device Software and install it using the application loader tool in BlackBerry Desktop Manager.I hope this information will be helpful to you
1helpful
My black berry just wont turn on its been charging for ours. a light would come up but .......
Hi, please do a hard reset on the BlackBerry smartphone.
install it using the application loader tool in BlackBerry Desktop Manager. I hope this information will help you
1helpful
My blackberry is not switching on
Open the back cover and clean the contacts with DRY CLOTH.
Make sure the BB and battery contacts are all line up.
Close the cover.
Use the wall charger to charge the BB for 2+ hours.
DO NOT use the USB data cable to charge your Blackberry.
When the PC/Laptop/Mac go to power saving/SLEEP mode it will cut off the charge to the Blackberry.
Plug the power pack in a different wall socket and it the Blackberry charge.
Nov 11, 2009 • Cell Phones
2answers
RIM Blackberry Curve 8310 stopped working
I hope battery is working fine,Please try charging in different wall socket and also try charging this phone using USB connected to computer..still if its not working then you can go to nearest service center..
2helpful
2answers
Phone wont stay on unless connected to power
i think your battery is to old, try buying a new battery
Top RIM Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
k24674
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
