1996 Honda RVF 400 NC35 Logo
A
Anonymous Posted on Jun 01, 2012
1996 Honda RVF 400 NC35 how to change the fork seals @
evan morrow
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 4 Answers
  • Posted on Dec 29, 2017
evan morrow
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
Helped
3331
Points
15
This type of R/R is what I call a straight monkey see...monkey do repair. Undo the drain screw on each fork and drain oil. The bike must be high enough off the ground to slide the sliders off unimpeded. From there let pressure off via the schrader valves on the forks, if so equipped. Remove wheel and unbolt anything attached to sliders because these must be taken to the bench. At the bottom of each slider, remove bolt and slide the slider off fork tube. Take slider to bench and remove internal snap ring and carefully pry the old seals out without damaging anything. Grease the new seals and carefully tap seal into slider evenly. A deep well socket can be used to tap it all the way in. From there it's reverse procedure. Add fork oil to specs.
1 Related Answer
Anonymous
  • 292 Answers
  • Posted on Apr 03, 2009
SOURCE: Need to change fork seals on xr400
http://www.carlsalter.com/motorcycle-manuals.asp
free pdf service manual here
Hi everyone, I need some advise on what to check so my rvf400 can start. Just put a new charged battery, lights came on but I got nothing after that. Check fuses and voltage everything all good. Do I need...
The fact that the battery was removed leads me to believe that the computer has lost its memory and the ECU is at fault.
Seen many cars running into similar problems .
Check out this link
ECU removal
1helpful
My 1998 honda rvf 400 rt model is very hard to select neutral while bike is running,when switched off can be got no problem,what could be wrong,
the clutch is draging,,,take up some of the free play in the cable so when you pull the clutch in it disengages fully
I need to replace the seat on my rvf400 - can you advise me what the best option is?.......
retrimiing by auto upholsterer is a cheap way compared to a relacement seat
1helpful
Excessive Cam Noise
sounds like the valves are hitting the pistons. recheck cam timing and valve clearance.
Dismounting the rear wheel rvf 400
just undo the large i think its a 32mm nut in the centre of the wheel and your wheel should come off. remember to undo the brake and chain
1helpful
RVF 400R MISSING WHEN YOU REACH 6000RPM
you have to take time and check all your wires for breaks and to look for cutts in them.Check your handlebar swicthes .change your bulbs . Replace or ajest your brakelight swicth. You need to take off your carbs. and supmerge them in yamaha carb. cleaner in a deep pot. there cleaner does not hirt rubber.
Top Honda Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Mike Cairns
Mike Cairns
Are you a Honda Expert? Answer questions, earn points and help others
