Below are the Date and Time setting instructions for a similar model: OMRON BP742
http://omronhealthcare.com/products/5-series-upper-arm-blood-pressure-monitor-bp742/
Set the monitor to the current date and time before taking a measurement for the first time. If the date and time are not set correctly, the measurement values stored in the memory and the average values may not be correct.
1. TO START THE SETTING
Press the Date/Time Setting button ( ) to adjust the date and time.
The year flashes on the display.
2. SETTING THE YEAR
The year can be set between 2010 and 2040. When the
display reaches 2040, it will return to 2010.
Press the Up button ( ) to advance by one year.
Press the Date/Time Setting button ( ) to set the current
year.
The month flashes on the display.
NOTES:
• Press the Down button ( ) to decrease the date and time values.
• Press and hold the button to increase or decrease the date and time values faster.
3. SETTING THE MONTH
Press the Up button ( ) to advance by one month.
Press the Date/Time Setting button ( ) to set the current month.
The day flashes on the display.
4. SETTING THE DAY
Press the Up button ( ) to advance by one day.
day.
The hour flashes on the display.
5. SETTING THE HOUR
The time is set using AM or PM.
Press the Up button ( ) to advance by one hour.
Press the Date/Time Setting button ( ) to set the current hour.
The minute flashes on the display.
6. SETTING THE MINUTE
Press the Up button ( ) to advance by one minute.
Press the Date/Time Setting button ( ) to set the minute setting.
7. TO TURN THE MONITOR OFF
Press the START/STOP button.
NOTE:
The monitor will automatically turn off five minutes after the minute has been set
SOURCE (PDF User Instruction Manual):
http://omronhealthcare.com/wp-content/uploads/BP742_IM.pdf
I have verified that it does connect using Ethereal. The following sites get visitedhttp://server2.netinfostation.com/gettim... which returns the correct date andhttp://server2.netinfostation.com/getwea... (Garbled info returned - not sure if this is expected)
Doe not appear to be firewall related
Seems to be related to the weather server. See below thread for detailshttp://answers.microsoft.com/en-us/windo...
And from Sharper Image
We are sorry about this.
The internet service that provides the weather to your device is currently undergoing maintenance. The error you are receiving is not the fault of your receiver. All repairs should be completed within the next few days.
Thank you,
If you have a Sharper Image ES-WS115 five day forecast weather station I believe have found a way to return it to service. I picked up a unit at a local thrift store that was still brand new in the box with only the owners manual missing.
The manual is available at
https:/www.manualslib.com/manual/783137/sharper-image-ec-ws115.html
Unfortunately the installer program on the CD only directs your web browser to a server that no longer exists to download the program to your PC.
After considerable searching the web I suspected the manufacturer of this product is NSHnordic.com. I found a similar product of their Ventus model W194 4-day forecast weather station. At this point I was willing to forego the fifth day if it would at least give any functionality. I downloaded their installer program for the W194 fromhttps://www.nshnordic.com/english/suppor...
This installer did download the program to my PC which easily installed.
I found that I needed to reboot for the program to load at this point.
If you do not see the user interface and after clicking the "4-Day Forecast" icon, get the message "This program is running on your computer", I start the Task Manager (Control/Alt/Delete), select the "Processes" tab, then select 4-Day Forecast.exe and then click the "End Process" button. Now when you start the program the user interface will display the first time you restart the program.
Once the program runs you should see the user interface and select the "HOME WEATHER" tab at the top then setting... button at the bottom. then click the "SET LOCATION" button make you selections then the "SAVE" button. Then select your preferences for Temperature, Wind speed, Time format, etc. Then click the "Save" button. At this point the program should display the current weather data. It's important you set-up the "Home Weather" as this is the data that will be sent by the transmitter to the main unit's display.
At this point I had trouble getting the weather data to transmit over to the display unit.
I wish I knew exactly what I did that finally worked but here are some of the things I tried.
1. Pressing the button on the bottom of the transmitter forces the unit to send data.
2. Disconnect the transmitter from the USB port, remove the batteries, wait a few seconds, reinstall the batteries, use a straightened paper clip the depress the reset button thru the small hole marked "R" visible with the battery cover removed near the "CE" molded on the bottom.
3. Uninstall and reinstall the program. This requires resetting your location and preferences info again and may require a reboot.
The data did slowly transferred to the display so give it a few minutes.
Happily, despite the software being designed for a 4-day forecast unit, I am getting all 5 days populated with all appropriate data.
Be persistent and good luck.
John
