One of my nozzles at the dispenser seems to be blocked. I have tried clearing it with a paper clip which appears to have no effect. I looked at trying to remove the dial so I could remove the cover plate and see what was happening inside but was unable to see how it could be removed. Any advice is appreciated.
First, I'm Not a Saeco Representative, though I have worked on some Saeco machines.
** Most cases of one side not dispensing coffee is usually coffee that has dried and built up over time to coat the least used spout. This is caused by the machine not being flushed or cleaned daily.
** Follow the MFR's daily cleaning instructions to keep you unit operating properly.
** fill a glass up of water to the rim and place on drain tray. the water in the cup should be even with the glass lip all around the cup. If it's leaning to one side then your machine (or table it on) needs to be level in order for the spout to dispense evenly. Another way to check is to place 2 shot glasses under each spout and brew a double shot. Both should fill at the same time and be the same amount when finished.
** Check your MFR's kit to see if there is a small brush to allow for nozzle cleaning. Otherwise follow the cleaning instructions and do multiple cleanings to get rid of the coffee residue. Once cleaned you need to maintain a regular cleaning schedule.
** There are no serviceable parts in these small home machines. Suggest contacting your vendor or Saeco for service or replacement.
Aloha! ukeboy57
How do I attach a video to this question?
Would appreciate any advice on how I am able to attach a video to this question, if anyone knows how. Thanks :)
