Sandisk 4 GB Standard SDHC Card with Rezo 15 Camera Pouch (SD4GBRZO15BN) Logo
Posted on Jun 01, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why wont my computer recognize my sandisk memory card anymore
Computer wont recognize any memory card i stick in the slot anymore. Theyve all worked fine before it justed started happening 3 days ago
Anonymous
Level 2:
New Friend:
  • Expert 47 Answers
  • Posted on Jun 01, 2012
Anonymous
Expert
Level 2:
New Friend:
Answers
47
Questions
0
Helped
10573
Points
139
Sometimes it happens that your slot doesn't work you can use a another option like Olympus LS-10 digital recorder as a card reader for accessing the data. Insert the SD card in your LS-10 digital recorder then connect the recorder to the computer with a USB cord then it will show you two options for the onboard storage inherent and one for the SD-Card. Select first photoshop elements to read the card and then Windows Live photo Gallery to view and copy your photos.
If the Information helped you out then please give me some ratings. Thanks
How do i get pictures off my sony memory stick pro duo with adapter on to my hp laptop
You will need to purchase an adapter that will fit the SD card slot or USB connector. When connected, use the computer to open the files from your memory card and save them on your computer.
These adapters are available from big box stores and online from eBay and Amazon.
4helpful
LG800G wont recognize 4gb micro sd card
The LG800G works with microSD cards. Your 4GB card is actually a microSDHC card. While it fits into the slot, it's electronically incompatible and will not work with this phone. You need to use microSD cards, 2GB and smaller.
1helpful
I bought a 4 gig SanDisk Adapter micro SD, micro SDHC. my Acer Aspire will not recognize the card, i've tried the switch both ways multiple times. how can i get my PC to recognize the card?
My reader will not read mine either. I use a usb key card reader. It used to read the regular old SD cards but the new HC card format wont work. This is due to UDF differences. You can try to reformat the card but then your camera or device may not recognize it anymore. good luck
WONT BE RECOGNIZED BY MY COMPUTER SIEMENS FUJITSU (WINDOWS XP SP3)
Try the device in some other USB port on your computer.
Try the device in some other computer.
2answers
No source will read my memory stick pro duo mark 2
  1. Try re-formatting your memory stick from your PSP console. A memory stick that is formatted from a PC or other hand held console sometimes cause incompatibility problem with the PSP.
  2. If your PSP still can not read the memory stick, try checking your memory stick by using your friends PSP and see if they can access the memory stick.
  3. If the memory stick can be accessed by your friends PSP then there is a problem with the memory slot of your PSP.
  4. The only way to check the contacts of the memory slot of your PSP is to disassemble you PSP and take out the mother board.
1helpful
My won't recognize my Sandisk memory stick
may be ur computer is not able to read the stick, try it on another PC, some times the memory stick has some power left in it when removing from the camera and the same has to be discharged, to do this refit the stick to you camera and access the stick, then shut down the camera by power off button of the camera and then remove the stick from the camera and connect it to the PC.
2answers
Computer does not recognize 2GB Memory Stick
Format as Fat 16. Also, Sandisk has a solution to this on their site. http://www.sandisk.com/DriverDownload/index.asp
SanDisk Memory Stick Pro Duo problem
it may be lost, safely remove your hardware befor you get off from the computer
4helpful
5answers
Micro SD 2 GB just stopped working
The PIC or EEPROM inside these cards may not be working. I guess you best bet is to buy a new one try Kingston brand or go with another Sandisk.
Top SanDisk Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a SanDisk Camera Expert? Answer questions, earn points and help others
