Mashing that envelope button doesn't always work. It doesn't work on ours. Instead, pick up the phone and dial 1000. Then it says your extension. Then you type in your passcode/pin and then the voice prompts start. If you are at another desk, dial 1000, it says the extension you are at, then press star key, then press YOUR extension number followed by the star key, then type in your pin/passcode and the voice prompts start.
SOURCE: How do I set up
Dial the Voicemail access number, you should be prompted with a passcode. If you've never set it up before the passcode should be 1111. If this helps, follow the prompts.
Assuming you have the Embedded Voicemail... dial the Voicemail access number... it should recognize your extension number and prompt for a passcode - the default is 1111. Follow the prompts to set it up.
If the mailbox is already set up from a previous user, have your administrator reset it.
SOURCE: MITEL 5224-how do you set up your voicemail??
I have this phone at work. There's a button that looks like an envelope. Touch that and it will prompt you through recording your voice mail. This phone also features various "away" messages so that you can record a couple different ones and then activate whichever you want depending on your day. This is also accessed through the voicemail button. Once you play around with it a little, you'll find it's a rather simple phone. Right now, I'm trying to figure out how to access my voicemail from home! Good luck!
