Brother HL 5250DN Laser Printer Logo
Anonymous Posted on Jun 01, 2012
My Brother HL-5250dn prints grey lines down the page, sometimes up to 4 evenly spaced.
I've replaced the drum and toner cartridge several times. It doesn't seem to help.
  • Alan Rothery Jun 01, 2012
    Do your lines appear running top to bottom of the paper or left to right  as the paper comes out of the printer? Also are there any signs of lines on the back "non printed side of the page" ?
  • Anonymous Jun 01, 2012
    The lines run down the page, top to bottom, on the printed side only. Do you think it is the fuser? As I said in my comments, I have already changed the drum. However, it is a remanufactured drum, not an oem from Brother, which are really expensive.
Tareq Bin Mostaq
Level 2:
Champion:
  • Expert 205 Answers
  • Posted on Jun 06, 2019
Tareq Bin Mostaq
Expert
Level 2:
Champion:
Answers
205
Questions
5
Helped
112271
Points
323
Need printer service ,some times when the laser unit dirty than u should clean all optical mirror inside laser unit. sometime comes from drum , also if the fuser unit defective, last chance change toner cartridge.
5 Related Answers
Anonymous
  • 152 Answers
  • Posted on Feb 29, 2008
SOURCE: Dark line down printed page
problem in your fuser assy call to hardware service provider
Anonymous
  • Posted on Aug 14, 2008
SOURCE: toner light after 1K pages
On my unit, the toner light was lit steady amber and the Status light was steady red. I tore a small square out of a post it note, off the top (so that it had adhesive on it), and used that to cover the sensor path way found on either side of the toner cartridge. It is a clear plastic hole, centered toward the bottom of either side of the cartridge.
Anonymous
  • 405 Answers
  • Posted on Mar 27, 2010
SOURCE: brother hl 5140 drum light comes on then off every 4
With the front cover open, press and hold down Go button until all 4 LEDs are lit. Once all 4 LEDs are lit, release the go button, then close the front cover.
This will reset the drum counter.
Beymer
  • 20 Answers
  • Posted on Mar 05, 2011
SOURCE: I've installed a new drum AND a new toner
Try this....
1: Turn off power and remove toner/drum
2: Tape the little spring loaded lever just inside the printer on the upper left hand side in the *DOWN* position! Do not replace drum yet and...
3: Turn power on to printer and let it cycle. Status/Toner lights will come on as usual.
4: Turn off printer, remove tape from lever, replace drum and turn back on.
Beymer
  • 20 Answers
SOURCE: Brother HL-5250 printer toner Light on but Cartridge has Toner it
Try this....
3helpful
I have a 525DN Brother Printer which has started printing a line in the middle of the papers and dumping ink out of the left side of the cartridge - do you know what may be wrong?
Thin line? Print a diagnostic page (3 pushes on the go button) and try changing the toner cartridge or drum, depending of the page says.
2helpful
Drum light is blinking and not sure how to change it or fix it in Brother HL-5250DN
Hit the purple/blue button on the top of the printer 3 times. This will print a settings report of the printer showing you the toner levels and the drum life.
If you need a new drum purchase one. (I would suggest a new printer at this time but if you like it continue on)
Open the front of the printer and pull out the toner and the drum cartridge. The drum is on the bottom of the toner. Disconnect the drum from the toner and connect the new drum. Replace the toner/drum and you are good to go.
6helpful
I've installed a new drum AND a new toner cartridge. have followed all directions to reset the drum and the light still flashes and I can't print, this is for a brother HL-5250DN printer
Try this....
I have a Brother 5240 printer. The toner light
Try this... it reads the level of the toner and can become faulty. This clears it.
2answers
Brother HL-5250DN Laser Printer TONER LIGHT ON & NO PRIN PAGE
When the toner light is on this means the toner is empty and needs to be replaced before it can print again. Replace the toner and you will be able to print again.
Fuser Problem?? The ink does not cover the left side of the page
Pull out the toner/drum and on the backside there is a blueish/purple tab, it slides from side to side along a corona wire. Move the tab back and forth several times and then put the toner/drum back in and reprint.
Below are the instructions on how to accomplish this task.
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000200/000008/faq000208_018.html?reg=us&c=us&lang=en&prod=hl4070cdw_all
5helpful
Try this....
Prints documents but there is a grey hue on all the pages
You might try changing the toner cartridge. While you have the toner drum cartridge out, clean the carona wire by moving the blue tab on the drum to the left and right several times. Be sure to store the tab all the way to the left before you reinsert the drum/toner cartridge assembly.
2answers
Vertical black lines printing down page - changed toner without success
Hi Mike,
Check the drum. Take the drum and toner out of printer. Remove the toner and check the drum. Probably scratched.
S88
Brother HL-5250DN
call brother and tell them that the drum is shadowing and needs to be replaced or you can look in your area for a cartridge World and pay them to remanufacture that drum and If you are going to be printing check you really need to find a printer that has micr toner it has more metal ion the toner which makes it burn hotter.The toner that you are using may possibly be able to be lifted and info on the check could be [email protected]
Norman Weimar
Norman Weimar
k24674
