Tip & How-To about Roomba Robotic Floor Bagless Vacuum
If your Roomba is not performing as it did when new do this. Remove the outet body and clean the dust build up inside the unit. Then gently use 5 PSI of air pressure to blow away the excess dirt. Also clean the inner body casing you removed as well. Sensors in the Roomba get dirty and causes this malfunction. Radio Shack sells compressed air in cans which will work great for you when doing this proceedure.
