Cannot figure out how to reset for US time zone; it now shows 4 hours ahead. Thank you
To set up your clock simply install one fresh AA, LR6 ALKALINE battery. Due to the nature of long wave radio signals it is normally not possible to receive a signal during the day so it is best to install the battery late in the evening. Select your time zone by pressing one of the four time zone buttons PT-Pacific Time, MT-Mountain Time, CT-Central Time, ET-Eastern Time. The time zone buttons may be pressed any time after installing the batteries. If multiple buttons are pressed the clock will set to the time zone selected last. If no time zone is selected the clock will default to Pacific Time. Another time zone can be selected during or after the clock has set itself. Your clock can only set itself to one of the four time zones stated above. For time zones outside of PT, MT, CT or ET you must manually set the time using the Manual Time set button on the back of the movement.
When the battery is installed the second hand will advance eight seconds (two seconds per step x four steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each
hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
SOURCE: La Crosse atomic clock model #WT-3143
don't push any buttons at all untill the clock has at least 15 minutes to communicate with the transmitter.
SOURCE: Resetting to daylight savings time.
The clock is searching for a strong enough radio signal from NIST station WWVB. When it can't lock on it, it gives up, moves the dial four hours, and goes to sleep to wait for better reception. Put the clock in a window facing towards Boulder, CO, overnight. (Radio propagation is better after dark.)
SOURCE: Atomic Clock Daylight Savings
Your clock may need to receive a signal indicating the time change. You can try moving it to another room, or outside to see if it reads the signal. Mine didn't, so I removed the battery and reset the clock. It wasn't obvious how to do that and I didn't save the owner's manual but upon close inspection there was a tiny black button (that looks like where you would lift a cover for a battery) and pressing it allowed me to adjust to the correct time. It is a "Sharp" bought at Target a couple of years ago.
SOURCE: We have an atomic clock with calendar and
Press and hold the SET key for 5 seconds. Press set key repeatedly until TZ is displayed on the bottom. Use the "+" key to set the time zone. -8 is for Pacific Time Zone, it will display -8 PST in the display. Press set to go to the DST setting, and so on until you've cycled through the options.
SOURCE: I can't get my atomic wall clock to set on daylite La cross wall
The easiest way to reset it would be to change it to Eastern time - that will give you the correct Central DST.
Bill B
