Which red light? The one on top of the dash? If so, there are two cases where that light will flash rapidly: If you use the wrong programmed key, it will immediately start flashing rapidly when you turn on the ignition and try to start the car. If the light is steady and then starts flashing rapidly after a few seconds when you turn on the ignition or try to start the car, you are using the correct programmed key but the engine computer has a problem or has failed.
SOURCE: 2002 ford crown vic. driver side wiper not
the linkage between the wiper motor and the wiper arms needs to be replaced. the stud on the one side is stripped and that is why it doesn't work as it should. this happens usually when the wipers are left on in the winter with the blades freezing to the windsheild. turn on the car with frozen blades tends to strip out the teeth holding the wiper arms onto the linkage
SOURCE: 2005 Crown Vic Police Interceptor: Starts then stalls
Have you checked the fuel filter. Fuel pump will pressure up, but fuel filter could be clogged and not work without the pressure of the fuel pump.
SOURCE: My 99 Crown Vic acts like it isn't getting gas
check for clogged fuel filter first, usually the pump works or it dosen't, check and get back to me.
SOURCE: hi i got an 03 crown vic, the airbag light come on
dealer only ,classed as safety so its encrypted software ,either sell it quick or be prepared to pay up to 2000euros .It will not pass the annual vehicle mechanical inspection like this
