When switch on it works till settings (date and time etc) few while diplay is gong to blue (no details) Also phone is on
SOURCE: Blue screen on main display
Hi. this reoccurring error is due to programing and hardware failure. you will need to remove the battery for 5 minute. if the error continues after you re insert the battery, this will confirm this fault in the hardware. your phone will require repair in this case.
SOURCE: Nokia 3230 screen goes blank after a few minutes of turning on.
hello !
replace the LCD theres a posibilty of it being foulty , the IC on the lcd is damaged and please check the lcd socket on the MB .
Thank you
its a hardware problem, its FPC cable is tampered plz get it replaced by Nokia Care or call me at 99999-16148 India
SOURCE: Nokia 2600 time display
I'm a cell phone sales representative and I came across a customer that had a similar problem.
What I found with her, she had so many icons displayed along the top row of the phone that the phone simply did not have room to display the time.
By clearing out her text message inbox, the sent messages, the outbox and being sure all of her voicemails had been checked, a number of the icons disappeared off the top of the screen and so the phone started to display the time again.
So that solve the problem for her. Hopefully it can help you as well.
You most likely need a new ribbon cable, which is the cable that connects the two halves of the phone. They are not expensive and can be ordered on eBay, and they come with the tools required to disassemble the phone and replace the cable.
First change the display & see and if not put software. if not see hardware
